Problems with cast pistons? 9.44/8.13 scr/dcr
Posted: December 3rd, 2010, 3:57 pm
				.030 overbore
0 deck ht
.043 quench
5.875 rods
Comp 68-232-4 cam
64.2 cc chambers (raised roof from hot 4.2 liter build)
I want to run 87 to 91 octane.
I use to run 9.875 SCR and 8.4 DCR using hypereutectic pistons but that was with 3 2bbl Webers and distributor I could tune. It ran good on 87 octane and great on 91 octane. Since the stroker will be computer controlled and not an IR intake & mechnanical distributor I wont have such good control over mixture or spark advance.
I have two choices in pistons, Sealed power hypereutectic H802cp/H825cp 15.1 cc (9.67 SCR/8.31 DCR)
DCR seems high for 87 octane.
or
Sealed power cast 677P or 525P 17.5 cc (I will adjust deck for .043 quench) giving a 9.44 SCR and an 8.12 DCR
The cast pistons seem much better for getting an 87 octane motor but I have never built with cast pistons at this high a compression ratio before.
Two questions:
1) has anyone run a cast piston in a stroker at 9.4 or greater SCR?
2) has anyone had a problem with a cast piston at this SCR?
For what its worth here is a summary of posts on SCR-DCR Quench and octane on the board.
SCR/DCR/Quench/octane
9.2/7.96/87
9.875/8.51/.050/93
9.25/8.03/.080/91-87 blend
9.25/7.8/.043/87
9.4/8.0/.048/89
9.25/7.8/.043/87
9.6/8.1/.043/87 (bratcop, chip and tuning)
			0 deck ht
.043 quench
5.875 rods
Comp 68-232-4 cam
or
Two questions:
9.2/7.96/87
9.875/8.51/.050/93
9.25/7.8/.043/87
9.4/8.0/.048/89
9.25/7.8/.043/87
