Best Stock 4L cam
Posted: August 3rd, 2010, 7:19 am
by Carter Off-Road
Im wanting to stroke my 05 tj but more in the long run. For now i basically just want to put a real nice (big lopey) cam in it and have a nice valvetrain and head port job done. This is where you guys come in to save the day so i dont make mistakes. Whats the best cam to run for the muscle car sound make power and still have decent driveability. This is not my DD i have a little s10 for that. And im sure theres other post like this somewhere i just wanted it in my own words. And should i keep flat tappet or go hyd roller? Thanks a ton
Re: Best Stock 4L cam
Posted: August 3rd, 2010, 8:08 am
by lafrad
You will NEVER get a lopey muscle car sound out of an I6.
It will sound angry and unhappy, but never muscle-car-y.
As for suggestions... if you are just looking for the SOUND, talk to one of the cam companies and get a custom grind. Start with an intake lobe from a "stage 1" or "stage 2" cam.. (in the 205 - 210 duration range) and then take the exhaust lobe from an "EXTREEEMEEE!!!!" cam... something in the 220 - 230 duration range. Do something like a : 210 int / 225 exh @ 107 lsa Install it at a 108 ICL, and you should have a "moderately torquy" cam that isn't totally lame up at high rpm, but with a definate "I6 Lope" and a very VERY sharp exhaust note.
This is basically building one of comp cams "Thumpr" cams for the jeep. after seeing the problems that people have had with cams, i would suggest NOT reusing a cam. EVER. If/when you go to the stroker, bump those cam figures up 10* each... the displacement will be able to better take advantage of more intake duration... (220/235 @ 107 lsa)
Posted: August 3rd, 2010, 8:10 am
by lafrad
Both of those cams will be out-performed by cams with POWER as their main goal. but they will definately sound badass....
Posted: August 3rd, 2010, 3:10 pm
by Carter Off-Road
I guess i didnt mean muscle car sound more like a nice small block pushrod motor. Heres a good video...keep in mind this is a 4.7 with a turbo on it. http://www.youtube.com/watch?v=cQ2_VtMB6AI
Posted: August 3rd, 2010, 7:42 pm
by IH 392
lafrad wrote:You will NEVER get a lopey muscle car sound out of an I6.
YEP, we have the biggest cam (hydraulic) Crower grinds for the AMC six in one of our race cars, it's a 232 and when it warms up it smooths out and sounds rather stock, the cam in the Jeep in the video is ground to take advantage of the turbo, it would have no power in a normally aspirated engine.
Posted: August 4th, 2010, 7:11 am
by lafrad
Oh I'm sure you can get lope... thing is, all cross plane V8's that you have ever heard have a firing order that is "uneven" for each 4-cyl bank. This, along with lope, gives it the "agressive nasty idle" sound.
An i6 has a perfectly even exhaust pulse in the big header, and is perfectly even in duals if you split the banks up front to back (like many people do). This just means any lope (misfires) will be mixed in with smooth running operation of the other, running cylinders.
The trubo car has a cam thats setup to take advantage of the turbo, AND, it has a turbo. both those change the sound of the vehicle in a significant way.
You wouldn't want that cam in your jeep... unless, of course, you put the turbo in too...
