4.6 Stroker stumbling at low RPMs - Help!
Posted: July 12th, 2010, 5:23 pm
				Hi all, first post here hoping someone can give me a few clues - please!
I completed my first stroker installation into my 1984 CJ-7 w/- NV3550 a couple of weeks ago - here are some basic details:
Donors - OBD1 4.0 came from a 1994 XJ Limited AW4 Auto (300,000km odo) crank came from 1984 4CW 258
Full rebuild - 0.30" over, decked block, Comp 68-232-4, dished a set of H802CP pistons for 9.7CR, ported the 7120 head and matched it to manifold, 63mm TB, K&N FIPK (4.0 YJ), Banks Torque Tubes (4.0 YJ), 24lb ford injectors. Nothing unusual about any of it. I'm loving it in the CJ - it is just great, aside from one niggly little issue:
When I start it and drive it in open-loop mode, it doesn't miss a beat. Runs perfectly.
When I sink the boot in or really nail it (WOT), it doesn't miss a beat. Just thumps out the power and howls up the RPM scale.
But:
When it's warmed up, in closed-loop mode and at low to mid rpms, if I just moderately open the throttle, it burps and chugs and gags and carries on until I either back right off or sink the boot in. If i really eeeeeeeeease the throttle on it doesn't complain, but I can't drive like Grandma the whole time. If I continually drive it like I stole it, it doesnt complain, but I can't do that either! Another way of describing this fault - at lower RPMs, if I drop the manifold pressure a bit (but not dramatically) with throttle, it protests.
Tests done to date:
I've replaced a new O2 sensor with another new O2 sensor - no change in fault. O2 sensor not damaged or sooty.
I started out running 27lb injectors - I swapped these for 24lb - no change in fault.
The IAT sensor is just a little off spec, low side. Cold morning (about 10C) and it was 16k ohms.
I disconnected the PCM and injected a regulated 5V signal into the TPS and MAP supply line. TPS range was 0.6V (idle) to 3.7V (WOT) and the range appeared smooth on a DVM.
MAP was on spec for the ambient (4.5V) pressure and if I really pulled all the air out of the connecting hose (that fuel residue doesn't taste very nice) I could just get it to 2.1V. MAP and TPS are original XJ donor bits.
Other considerations:
I can't find any manifold leaks, including in the brake booster. It doesn't mean there aren't any, but the perfect open loop operation and clean idle suggest to me that this is not the cause. I can't find any ignition fault and the very narrow circumstances under which it misbehaves doesn't point to coil etc even though this is an original XJ part.
I've temporarily grounded PCM line #29 so the PCM thinks the brakes are not being applied, until I can integrate the XJ's brake switch (haven't had time) This changed the way the engine behaved when pulling up at the lights - it now waits until VSS goes to zero then neatly steps the idle down to the correct RPMS - but did nothing to change the fault.
A couple of theories:
Is the 4.0 TPS for an AW4 Auto a different resistance to the one for a manual trans? With the NV3550 I no longer have the TCM in that circuit.
Going into a CJ, I've tried to properly ground everything to avoid earth voltage loops, but now I recall the PCM earth is to the LH fender while the sensor earths are on the engine block. I've bonded block to body but could there be an error voltage creeping into the O2 sensor circuit?
Fuel economy seems within bounds for a stroker still running in with less than 1000km on it: 14.5-15litres/100km (15.7-16.5MPG) in city traffic. This suggests no overall bias to rich or lean?
I have a 180 deg F thermostat in. The engine warms up properly and goes into closed loop mode within a minute or two, but it's winter here in Australia and mornings are 5-6 deg C (41-43 deg F). I have a brand new three core triple flow radiator so cooling is very effective and the engine won't be getting far over the thermostat temp of 180 deg F. Could this contribute to it?
Any other ideas? Any help greatly appreciated!
But:
Tests done to date:
