first stroker help help help
Posted: July 8th, 2010, 6:50 am
Hello,
I am debating wether or not to build a stroker. I currently have a 258 with a 4.0 head running the obdI injection. I recently developed a knock/noise and started looking for a potential builder block. I found a 1988 renix 4.0 that was recently rebuilt. It turns out the owner has more money than sense and built the motor for a cherokee crawler then after a few trail runs decided to rebuild the entire rig and start with a 5.7 vortec and go to dana 60's. The story he gave me is his father owns the local napa and his brother own a machine shop and they built the motor for him. The motor was bored .30 over and had all new parts installed. My question to the stroker guru's is this a good starting point for a stroker build??? I know nothing if the motor has been decked or what pistons were used. Is it possible to take this motor swap rebuilt 4.0HO head and swap in my 90 258 crank and rods??? What problems would develop and what other work would need to be done to make this a proper stroker that will be reliable??
thanks in advance
I was thinking of using the rock crawler recipe
Jeep 4.2L 3.895" stroke crank
Jeep 4.2L 5.875" rods
Silvolite UEM-2229 +0.030" bore pistons
Increase piston dish volume to 30cc
8.75:1 CR
Mill block deck 0.035"
0.058" quench height
Ford 24lb/hr injectors with stock 39psi FPR for '87-'95 engines, stock injectors with stock 49psi FPR for '96 and later engines
240hp @ 4700rpm, 315lbft @ 3000rpmteam ramrod
Thanks Given: 0
Thanks Received: 0
RSS
Private messageE-mail team ramrod
thanks in advance
8.75:1 CR
Thanks Given: 0
Thanks Received: 0
RSS
