Help with selecting the right spark plug
Posted: April 3rd, 2010, 4:21 pm
				Hello all,
Here's my situation, I have a 1998 Jeep Cherokee 4.0 4WD that was suffering from a blown head gasket. My solution was to not only repair the failed head gasket but to improve the efficiancy of the engine at the same time (the side effect of a more efficiant engine is more power, more power is always good!). After considerable research for the most cost effective ways to reach this goal I came up with the following: 1) use a later casting 0331 head to take advantage of the better port shapes and port velocities that these heads offer.
See the following posts for additional info : http://www.jeepstrokers.com/forum/viewt ... p?=5&t=226
http://www.jeepstrokers.com/forum/viewt ... ?f=5&t=480
2) use a 1999 and later style intake manifold for its advanced design and optimized flow characteristics
3) use an aftermarket tubular header that meets my local SMOG requirements, I choose a GIBSON header.
4) use an aftermarket cat back exhaust system, I choose the DynoMax brand due to past good expierances with
their product, that coupled with a total purchase price of $15.00 for the system thanks to their $75.00 cash back promotion and an online discount at the time of purchase didn't hurt my discission any either!
5) "repair" the factory kink in the header down pipe, the was done with my oxy accetylene torch and various prying devices.
Now, my question is this, should I use a spark plug for the factory 0630 head or the newer 0331 head? Using NGK's web site, the factory replacement plug is a FR51 for the 0630 head or a ZFR5N for the 0331 head. The only difference is the porcelain and electrode on the ZFR5N plug for the newer 0331 head equipped engine is LONGER than the porcelain and electrode on the FR51 plug for the factory equipped 0630 head. All other parameters are the same, heat range, thread diameter and length, etc... I am worried about the plug making contact with the piston, detonation, emissions related garbage, and anything else that my good friend Mr. Murphy can possibly throw at me!
The newer head is already installed with everything hooked up and ready to run, this is my last hurdle to clear before I twist the key and hear my Jeep roar to life again. Some extra info - the bottom end of the engine is 100% factory, therefore I am running the factory dished type pistons that have the number 4 embossed on top along with the factory cam, lifters, etc.
Hopefully I can get the answer I need and bring the old girl back to life.
If you've made it this far, I congratulate you! If you have any helpful input you have my everlasting gratitude!
