Flywheel Questions (Stroker Build)
Posted: January 4th, 2010, 1:15 pm
				I used a 1994 XJ block with a 1989 YJ crank and rods. I have the wiring harness for the XJ block.
I am wondering if I can use the 1989 YJ flywheel when I finish the assembling of the engine. I know the new wiring harness will need a CPS. The CPS reads the notches on the flywheel.
Should I just pony up the money for a 1994 XJ flywheel to be sure the notches for the CPS are correct?
What have those that have built a stroker done?
