				AX-15 with a Stroker
				Posted: December 18th, 2009, 6:53 am
				by hvacman
				Alright, I have just started the install of my stroker engine on my project YJ. Here is what I have so far:
4.7 Stroker
AX-15
8.8 Rear Axle
Waggy 44 Front Axle
I am reusing the AX-15 from the YJ. I just had an interesting thing brought up though. The original 4.2 engine used a carb. So that means there was no computer. I did get the wiring harness that came with the engine.
I am installing the transmission this weekend. Now I am beginning to think about how the harness hooks to the transmission. I think the computer is going to be looking to the transmission for some info.
What do you guys recommend? Is there a way to reuse the tranny, or will I need to get one with the right sensors in it?
				Re: AX-15 with a Stroker
				Posted: December 18th, 2009, 7:39 am
				by gradon
				The only info from the ax15 tranny/x-fer case is the speed sensor.
				Posted: December 18th, 2009, 11:29 am
				by hvacman
				Someone just told me about a crank sensor. I was also told to use a different flywheel.
My problem is that the old AX-15 was to a carb engine. I am now going to a throttle body HO engine.
Any ideas on this?
				Posted: December 18th, 2009, 2:23 pm
				by Plechtan
				Read This:
http://www.jeepstrokers.com/forum/viewt ... f=5&t=1447
You do need some kind of Crank position sensor.
				Posted: December 29th, 2009, 12:46 pm
				by Biggrnjeep97
				After extensive research, i wound up purchasing a kit from Advance Adapters to control the crank trigger. There are 2 companies on the market making balancer crank triggers, Advance Adapters and Hesco. Advance was cheaper from Summit racing by ~$30. Novak Conversions also has some good tech on there website and tech line. As in the post noted above, I contacted both Advance Adapters and Hesco about making my own crank trigger. I was told by both that it was proprietary info that they would not sell to the public.
Hope this helps. Post up what you end up doin.
-Will
http://www.advanceadapters.com/
http://www.novak-adapt.com/knowledge/tr ... ateway.htm
http://www.hescosc.com/shop.asp?catID=7533
				Posted: December 29th, 2009, 8:21 pm
				by IH 392
				If your bellhousing doesn't have the window for the pickup, you simply should have gotten a later bellhousing and use the stock pickup unit, probably way cheaper than any of those relocation kits?
				Posted: December 31st, 2009, 12:31 pm
				by Biggrnjeep97
				IH 392 wrote:If your bellhousing doesn't have the window for the pickup, you simply should have gotten a later bellhousing and use the stock pickup unit, probably way cheaper than any of those relocation kits?
Touche'!
				Posted: January 1st, 2010, 3:22 pm
				by Plechtan
Don't forget, you would also need the correct flywheel with the notches in it.
				Posted: January 2nd, 2010, 12:27 am
				by IH 392
				Plechtan wrote:IH 392 wrote:If your bellhousing doesn't have the window for the pickup, you simply should have gotten a later bellhousing and use the stock pickup unit, probably way cheaper than any of those relocation kits?
 True, and the correct one for you application too(Renix, OBDI these two MAY? be the same?, OBDII), I got one from the junk yard for $35, it was the WRONG one
 , I got the CORRECT one off of Craigs List for $20, my extra bellhousing is an early one and has the internal hydraulic throwout bearing, my Jeep uses the external slave cylinder, so you would need to get the correct bellhousing for you application too!
