I've started a mess as my 98xj popped a oil pump @ 280k
I've got ..
a 88 block, 95 head, next week a 9.2yj 4.2l
I already have a 01 intake and borala header ..
I hope to get the porting started this weekend (just a bit)
then pickup the 4.2l next week !
I have a 88 cam , a 98 cam and I'm hoping to get some $ up for a new one
but I was wondering if I had to use stock which is the best ?
also I learned that the 88 head used bider stems for the valves then the 95
..crap
ghetto garage build !
Re: ghetto garage build !
Can I use the girdle from my 98 block on the 88 block?
I've not seen it open yet, and I'm wondering if it's like a honda one
(alloy addition to the main caps machined into place)
- amcinstaller
- Vehicle Year: 1980
- Vehicle Make: AMC
- Vehicle Model: Spirit
i think you can use the main girdlw but youll need to space it out from the caps a little bit so it will clear the crank.
1980 AMC Spirit Restomod in Progress
thanks ..cheers
You will also need the main cap bolts with the stud end for the main girdle to fit.
SilverXJ wrote:You will also need the main cap bolts with the stud end for the main girdle to fit.
perfect , thanks ..they will be donated by the cause of the stroker
so if I've used the calculator right, the base stroker with the 258 rods and the 99/01 cam
makes for 9:79 s and the "perfect" 8:1 d , with the ford 24lbs injectors I should (at sea level)
be able to make this run on 89?
Users browsing this forum: No registered users and 22 guests
