Look what I scored today for free
- 1bolt
A 13" tire... no.. next to it... Yes that's it, a crankshaft and a set of rods encased in a 4.2 out of an "86-ish" CJ7 so it's either 4 counterweight with the long snout that needs grinding/spacer or it's not the long snout. I was hoping it was an old 12 cw but according to the owner it's not that old...
But I've still got some hope though... He didn't know if it had been rebuilt or not, but the first thing I noticed when he was telling me all this was that there's not one but TWO coats of paint on the block... that means it's probably been rebuilt more than once. Unless someone painted the thing while it was still in the Jeep. Which means who knows what's inside the thing. I'll Pull the pan tomorrow and find out.
Anyway this is what I mean when I say a stroker is a great value... Free 4.2's and 4.0's are out there.
Simon
Simon
- Learning to use the board
Re: Look what I scored today for free
I thought I did well when I got my complete 4.2L engine for $5.50! Looks like you outdid me. Well done! I'll also add that my engine was from a 1985 CJ and it had a 12 CW crankshaft. I bet that's what you have.
- oletshot
I got a '80 258 for $50 on my first attempt at get a crank and rods.
Upon disassembly, I found it to be a '79 or earlier 232.
I was pissed at myself for not checking the #s on the block. It wouldn't have helped, you couldn't read them. It's very hard to tell the 2 engines apart without block #s.
Second attempt went much better, late 80's 258 with 4wt crank and rods for $50. On a side note, while pulling the head, removed all head bolts and head wouldn't come off. Actually lifted entire engine off the ground by the head, still wouldn't come off. When I got it off, I found PO had installed a brand new (rebuilt) head and used silicon on the head gasket.
'98 XJ 2-door, '94 YJ.
- 1bolt
yeah the only problem with these things is what to do with the head, it took me a year to get rid of my last 4.2 head, for 50 bucks. Eventually found someone who wanted it to rebuild for their 4.2... Problem is the number of people who are putting a stock 4.2 head back on their rigs is pretty small... Bright spot is this head appears to be fresh.
By the time I'm done I'll get my gas money and time back out of it by selling the block and head on Ebay for a few bucks.
Simon
Simon
- Shark
found this one on craigslist today. is it worth is considering all i need is a crank and rods?
http://tampa.craigslist.org/pts/604521005.html
'95 XJ 4door 4.0 aw4 2" 31's
- seanyb505
- Stroker Displacement: 280ci
I dont think so, considering machining will need to be done.
That reminds me... I was in the junkyard a couple weeks ago looking for a transmission and I found an old cj5 that was in horrible shape. I popped the hood and it did have a 258. What was worse than the condition was that they had it in the pile of crap to go to the crusher. I dont blame them, it didnt look like anything left on it (save for engine) was complete, straight, or not rusted over. I went back to the desk to see about saving it for a while, so I could come back with tools or something the next day. The guy didnt know what I was talking about, so we walked out there together and by the time it got back it was gone! Forever! Never to make my Jeep go fast again. Sad story...
97 XJ 4.6
90 MJ 4.0 - sold
97 XJ 4.6
90 MJ 4.0 - sold
- 1bolt
for $350 you can buy rods and a crank that are reman'd...
Simon
Simon
- Muad'Dib
Speaking of 258's ... last time i was at the junkyard looking at stuff, there was an AMC car (not sure what it was.. it had like woodgrain on the outside like a wagoneer) that had a I6 in it... Is it a 258? Could i use anything out of it?
Im definetly a "Stroker" noob!
- Shark
was probably a 232Muad'Dib wrote:Speaking of 258's ... last time i was at the junkyard looking at stuff, there was an AMC car (not sure what it was.. it had like woodgrain on the outside like a wagoneer) that had a I6 in it... Is it a 258? Could i use anything out of it?
Do a search for amc 258 engine numbers. It should be stamped on the rt side of the engine. I got two 258 cranks out of junk yard amc cars. One was a hornet (standard journals) and one was a concord (.010 mains and rods) both 12 wt cranks. It should also say on a sticker under the hood, but you can't always go by that because the engine may have been changed at sometime.
Oh, and yes you can use the crank and rods.
- Muad'Dib
I wonder if its still there.. ill have to look when i get back from my 4000 mile trip
- 1bolt
Got another one yesterday this one was out of a 83 CJ also a 4 cw.
Two free 4.2's inside of a week!
Pulled the pans on both and pulled the front main cap and #1 rod end the newest one looks unused. Must have been a freak for changing oil.
On a side note... Both of them have Fram Oil filters... Coincidence
Simon
Simon
Users browsing this forum: Bing [Bot] and 18 guests
