Junkyard EFI swap, 4.0 flywheel help
- Vehicle Year: 1983
- Vehicle Make: AMC
- Vehicle Model: Eagle
I'm doing a junkyard EFI swap into my 83 Eagle wagon, keeping the .030 overbored 4.2, also using a 4.0 head, and ax15 transmission. I wanted to save some money and figured it would be more worthwhile to just swap an ax 15 in and use the sltock location for the cps, the bellhousing. The problem is, I'm sure the 4.0 flywheel is notched accordingly, and I'm not sure if there's a certain way I need to install it, since I'm using a stock bellhousing mounted sensor, instead of paying 300 dollars for a crank damper. Do I need to have the crank lined up in a certain way before bolting on the flywheel so the sensor reads it correctly?
Re: Junkyard EFI swap, 4.0 flywheel help
The flywheel can only go in one way.
88 CJ8, 4.5L Stroker ,P&P Head ,Compcam 68-231-4 cam , 4.0L Junkyard MPI , 99 Intake, Borla Header,2.5" Flowmaster + piping,Electric Fans;SUA 4" lift on 33" tires ;4.11's Dana 44 F&R LockRight , High Steer with CTM's ;OBA;Full Cage.
- amcinstaller
- Vehicle Year: 1980
- Vehicle Make: AMC
- Vehicle Model: Spirit
are you also on eaglenest?
1980 AMC Spirit Restomod in Progress
- Vehicle Make: AMC
Yeah, I've seen you on there as well.
- Jeep-Power
- Stroker Displacement: 4.3
- Vehicle Year: 1984
- Vehicle Make: AMC/Jeep
- Vehicle Model: CJ-7
eliv1 wrote:The flywheel can only go in one way.
OK-- so how do we ensure it goes on there correctly-- I'm thinking this is covered in the stroker section, as a stroker utilized the 4.0 flywheel on a 4.2 crank.
Let's search...
-- TallPeter
'84 CJ-7 - tonned & turbo'd
The bolt holes in the flywheel will only line up with the bolt holes in the crank one way.
- Jeep-Power
I've had my flywheel off more time that I can remember. I guess I forgot about that..
thanks!
thanks!
-- TallPeter
- Vehicle Make: AMC
thanks guys!
