Exhaust Manifolds Glowing!
Posted: June 25th, 2009, 10:10 pm
				I just installed and started my stroker.  At first the timing was a little off.  We adjusted it (without timing light) and started it again.  It seemed to run fine, so I started the 20 min cam break in, and 3 min into it the manifold was glowing red hot, so I shut it down.
Could it be? :
-Timing: Could incorrect timing cause this?
-Vacuum Problems: I have not connected the air box, just running off the throttle body
-Fuel Octane? I am just running the gas that it has in it already, 87 octane
Has anyone experienced this, or could any of the above have caused it? Thanks
Here are some specs on my engine:
4.6 Stroker
4.2 rods
4.2 Crank
stock 4.0 Pistons (.030 over)dished to 20cc
CompCams 68-115-4
New lifters
Stock head (not rebuilt)
24lbs used ford injectors
My Static Compresion ratio is calculated around 9.1:1 and dynamic is around 8.3:1
			Could it be? :
4.6 Stroker
4.2 rods
4.2 Crank
CompCams 68-115-4
New lifters
