pipe plug next to camshaft
Posted: May 8th, 2009, 12:13 pm
by StroktWJ
I got my 00 block back from the machine shop yesterday and noticed that the pipe plug next to the camshaft was missing, I checked my 94 block and there was a pipe plug in the hole. Is this necessary or is there a benefit to not putting a plug back in the hole? I will be running the earlier style camshaft & timing set.
Re: pipe plug next to camshaft
Posted: May 8th, 2009, 12:27 pm
by yuppiexj
You need it.
There should be one on the back (flywheel) side of the block as well.
Posted: May 8th, 2009, 12:34 pm
by Plechtan
The plug is in the end of the main oil galley that feeds all the lifters and bearings in the engine. if it is not in, you will not have any oil pressure. If you follow the hole from the center of the oil filter mount, you will see it intersects this hole.
Posted: May 8th, 2009, 12:39 pm
by StroktWJ
I have the pipe on the back of the block and the driverside, but not the one behind the cam gear.
Posted: May 8th, 2009, 12:43 pm
by StroktWJ
Plechtan wrote:The plug is in the end of the main oil galley that feeds all the lifters and bearings in the engine. if it is not in, you will not have any oil pressure. If you follow the hole from the center of the oil filter mount, you will see it intersects this hole.
That's what I was looking for! Thanks you just saved me some serious headaches!
