Page 7 of 11
Posted: October 8th, 2017, 6:09 pm
by jpradcliffe
I am interested in that, please advise.
Posted: October 8th, 2017, 8:45 pm
by Russ Pottenger
jpradcliffe wrote:I am interested in that, please advise.
No problem.
Feel free to shoot me a email or call and I'll be happy to go over some of the options and specifics with you
Bishop-Buehl Racing Engines
531 N. Lyall Avenue
West Covina, California 91790
Work (626) 967-1000
Cell (626) 673-2203
Email/PayPal:
[email protected]
Posted: November 27th, 2017, 11:07 am
by jpradcliffe
Hello.
Anyone have experience with the SEALED POWER PISTONS (P/N: 677AP)? They have a compression height of 1.585.
I measured the deck height and found that the front measures 9.4475 and the rear at 9.450.
With the 232 crank and 4.0 rods, these pistons will be approximately .010-.0125 out of the hole.
So if I use the stock .052 head gasket I'd have a .040 quench.
Right? Please advise.
Still a lil ways away from ordering that camshaft btw.
Posted: November 27th, 2017, 11:39 am
by jpradcliffe
Oops, that's been answered already, my bad.
Carry on.
Posted: February 27th, 2018, 2:29 pm
by Colorado_XJ_Guy
Cheromaniac wrote:Just added these to my stroker page. What do you think?
If you all thought that the old AMC 232 I6 crankshafts were only destined for scrapheap oblivion, think again. There are plenty of them around and with a 3.500" stroke, you can use them to convert a stock 4.0L engine into a 4.2L mini-stroker. While it doesn't have the displacement of an AMC 258 crank-based stroker, the 258 cranks are becoming increasingly scarce and expensive so a mini-stroker offers a low cost alternative to more HP/TQ:
4.2L Milder mini-stroker
AMC 232 3.500" stroke crank
Jeep 4.0L 6.125" rods
Increase piston dish volume to 15cc
9.6:1 CR
0.040" quench height
262hp @ 5200rpm, 302lbft @ 3750rpm
4.2L Wilder mini-stroker
10.1:1 CR
CompCams #68-235-4 210/218 degree camshaft
270hp @ 5300rpm, 306lbft @ 4000rpm
Not sure if this has been asked, but how would I increase the dish volume on the pistons? Would this be done at a machine shop? Thanks!
Posted: February 28th, 2018, 12:42 am
by Cheromaniac
Yeah, a machine shop should be able to do that for you.
Posted: March 3rd, 2018, 9:53 am
by Colorado_XJ_Guy
Cheromaniac wrote:Yeah, a machine shop should be able to do that for you.
Great thanks! Gonna start on the 4.2 mini milder stroker soon. Starting to collect parts...
Posted: March 3rd, 2018, 10:02 am
by Russ Pottenger
I put together a lot of these kits and offer a CNC modified option for the 2229 Silvolite Piston.
If I could be of any help feel free to contact me.
Russ
Posted: March 4th, 2018, 5:39 pm
by Colorado_XJ_Guy
Russ Pottenger wrote:I put together a lot of these kits and offer a CNC modified option for the 2229 Silvolite Piston.
Russ
PM sent.
Posted: March 19th, 2018, 9:51 am
by ghetdjc320
What work needs to be done to run the 12CW pre 71 cranks with an aw4?
Posted: March 19th, 2018, 12:15 pm
by Russ Pottenger
ghetdjc320 wrote:What work needs to be done to run the 12CW pre 71 cranks with an aw4?
The 258 cranks were the only ones offered with a 12 counterweight option.
The early 64-71 232 crankshaft had a flat rear flange.
Later 72-79 casting 3214722 came with the centering ring.
That's the one you want. It has a 2.500 length snout, so you'll have to shorten it or use one of my $35.00 spacers.
Hope this helps
Posted: March 30th, 2018, 2:23 pm
by jpradcliffe
How much dish can be taken out of the silvolites with this combo? Ie: down to what compression can we get to for a boosted application.
Please advise
Posted: March 30th, 2018, 9:34 pm
by Russ Pottenger
I've safely increased the dish to 26cc.
... That said if your planning to add boost, a forged piston upgrade would be advisable. At that point it would make more financial sense just to step up to a 4.6/4.7 build.
My .02
Posted: March 31st, 2018, 6:04 am
by jpradcliffe
Hmmm. Well, already I already have block back from machine shop and 232 crank polished and 4.0 rods set up for mini striker. Was just tossing around the idea of putting the m90 I have in my garage in it. Still yet to order piston and camshaft. Something to think about I guess.
Posted: March 31st, 2018, 4:01 pm
by Russ Pottenger
jpradcliffe wrote:Hmmm. Well, already I already have block back from machine shop and 232 crank polished and 4.0 rods set up for mini striker. Was just tossing around the idea of putting the m90 I have in my garage in it. Still yet to order piston and camshaft. Something to think about I guess.
If you already have your crankshaft and rods ready to go then maybe a custom 4032 forged piston might be worth considering under the circumstances.
The modified cast piston you're looking like $200.00 for the set or the Forged $495.00
I'd be more than happy to assist in either direction.
Russ
