Page 7 of 8
				Re: SCCA Turbo 5.0L MJ (Comanche Eliminator Project)
				Posted: August 1st, 2011, 9:26 pm
				by nick
				Posted: September 30th, 2011, 7:28 am
				by the grey ghost
				hi im doing a somilar build but alot less exspensive and i was wondering what size and about how deep did you drill and tap the bung for the know sensor on your high output block, it the last thing i need, and have you considered makin a tps adaptor to fit the high output throttle body as well? you need the throttle cable and bracket too, but ive read it works well
				Posted: September 30th, 2011, 8:55 am
				by gradon
				I'm assuming you meant the renix knock sensor?  We haven't done anything with that yet(not even positive we're gonna run one).  We will be making a TPS adapter and probably a TB adapter in order to use a bigger TB(68-70mm, dakota or mustang).  Right now we have to figure out why the crank doesn't want to spin(I don't want to put anymore force into it cause I will break that bolt off) now that the rings are installed(Nick's gotta look up the ring gap spec).  This build is obviously not on the same time-frame my weekend build was.
				Posted: October 27th, 2011, 7:18 am
				by Shark
				You mentioned an aluminum driveshaft, did you ever figure out what you were doing for that? Do you know of an over the counter stock aluminum DS from another vehicle that will fit? Ive been looking for one myself. From what ive found so far the '01 extended cab S10 is closest in length for the swb 4.0/ax15/d35.
				Posted: October 27th, 2011, 10:45 am
				by Shark
				As for the air dam, here is a NAXJA thread that evolved into discussing that topic:
http://www.naxja.org/forum/showthread.php?t=1072293
Apparently, a guy found one on ebay a few years ago and will possibly make a mold and reproduce them.
				Posted: January 13th, 2012, 5:27 am
				by carlitos
				Man that thing is going to be sick when u get it done
 I'm going to build a 5.0 for my Cherokee this year hope fully
				Posted: January 13th, 2012, 9:41 am
				by gradon
				Right now, those pics are as far it got.  Once the last two pistons were installed, the crank no longer spun via the crank bolt, so gonna have to take them back off and measure the ring end gaps and probably do some filing.
				Posted: January 2nd, 2013, 6:30 am
				by frauhansen
				and? whats next, after one year?
				Posted: February 13th, 2013, 7:34 am
				by gradon
				Two weeks ago I helped my brother replace a bad throw-out bearing in his '95 XJ.  He told me that we would finish building the engine this summer.
				Posted: February 13th, 2013, 7:14 pm
				by cruiser54
				the grey ghost wrote:hi im doing a somilar build but alot less exspensive and i was wondering what size and about how deep did you drill and tap the bung for the know sensor on your high output block, it the last thing i need, and have you considered makin a tps adaptor to fit the high output throttle body as well? you need the throttle cable and bracket too, but ive read it works well
Most HO blocks have the hole already drilled and tapped. At the very least, drilled.
				Posted: August 6th, 2013, 6:52 pm
				by honkysXJ
				Did this beast ever run? ?
				Posted: January 30th, 2014, 3:37 pm
				by beiwulf
				<bump>
Any status or updates.  Curious to know if it's running and if so how well.. turbo setup… misc details..
				Posted: February 1st, 2015, 9:30 am
				by gradon
				I saw Nick's Megasquirt simulation back in December with whatever dizzy he is using.  I think he is working on a FluidDamper conversion atm.  All I know is that the Eliminator will start out N/A and get the turbo down the line when the whole truck is sorted out.  I'll let him fill in the details(sorry it's been long and drawn out).
				Posted: February 1st, 2015, 1:53 pm
				by the_wrench116
				short answer no it never ran.
				Posted: February 1st, 2015, 2:41 pm
				by gradon
				It hasn't been built.
