Page 4 of 44
Re: New 4.6L stroker build
Posted: February 21st, 2009, 4:28 pm
by dwg86
Dude, that sucks. Was that a 12 wt. crank? Your best bet now will probably be to hit the local junkyards and hopefully find a good standard crank that can be turned .010 under. I have found 2 standard 12 wt. cranks at the local pull-apart. So they are out there.
Posted: February 21st, 2009, 5:24 pm
No, it was a 4 wt. I wanted a 12 wt, but the machine shop found the .01/.01 4wt I decided to get it because it wasn't turned a whole lot. I guess the machine shop didn't get the message that I wanted and to get it NOW.
Posted: February 21st, 2009, 6:03 pm
by dwg86
Maybe try some crankshaft companies like Standard Crankshaft, or Crankshaft Rebuilders(or try a google search). They might have something.
Check out this build viewtopic.php?f=8&t=645&start=0
Posted: February 22nd, 2009, 8:11 am
by dwg86
dwg86 wrote:Maybe try some crankshaft companies like Standard Crankshaft, or Crankshaft Rebuilders(or try a google search). They might have something.
Disregard the last part of my reply. I thought I was sending to someone else. I can't edit it.
Posted: February 23rd, 2009, 2:37 pm
Standard Crankshafts do not have any, but they can turn yours for ONLY $224.30... right. Flat Lander Racing would have sold me a .010/.010 for $395.. from what they said "If it has to be 10-10" I would think they would have to have done some welding on it, or give up one of their best ones.
However, the machine shop's crank supplier got a new shipment in and one of them is 10/10. Hopefully this one actually goes to us.
A good crank is getting hard to find.
Posted: February 26th, 2009, 9:16 am
by dwg86
any word on the crank?
Posted: February 26th, 2009, 4:28 pm
Don't know yet. I'll be checking in on Saturday with them. As of last they said it was on the way.
Posted: February 27th, 2009, 1:02 pm
by cavaliers1323
How much did the header coating run you?
Posted: February 27th, 2009, 3:11 pm
$213 shipped.
Posted: February 28th, 2009, 6:05 pm
They have a crank! Its is what I was originally going to get.. 4wt, 10/10. Not welded at all either. Once again we were unable to find a 12wt crank and it appears finding any decent 258 crank is getting hard. So they have the block bored, and hopefully next week they will start to really tear into it.
However, he is a bit concerned about my chosen quench. First, he said that the .041" uncompressed head gasket will compress to .038", which I hadn't taken into account. Is that correct for a MLS head gasket? Also, he recommended that I leave the piston in the bore .007" instead of the .004" that I requested. His logic is that with the quench pad being only on one side it will cause the piston to rock when at TDC and the gas/air is compressed, then drag on the way down. I may go that route considering that the quench will still be .045" if the gasket compresses to .038". Opinions?
Anyhow, here are some pics. First is the best I could get of the lifter bore groove that we did... hard to hold a flash light, manually focus a camera and then snap the picture. The second is how the block sits now, bored.
Posted: March 11th, 2009, 6:38 pm
Its moving along now. Block is bored and honed, rod bolts installed and rods resized. Went there today and the assembly partially installed to check deck clearance prior to decking. Maybe this Friday I will have a short block.. if not then sometime next week.
-Chris
Posted: March 12th, 2009, 4:54 pm
Found out today that the freeze plug kit is missing two 2" freeze plugs. Brass ones come in on Saturday. Of course its the one thing that I don't check that has to be wrong.
Anyway, everything has been balanced, decked and cam bearings installed. all that is left to do is final assembly, blue printing, freeze plugs. Each piston weighted 623 grams so no material removed from them.
Some pics for your enjoyment:
Crank on balancing machine:
Rods:
Rod heating machine used to install piston on rods:
As it sits now:
Cam bearings:
The offending freeze plug kit:
Posted: March 12th, 2009, 6:28 pm
by dwg86
Looking good.
Posted: March 12th, 2009, 7:45 pm
Yeah, its going to be ready soon. I'm going to paint it at the machine shop.. decided against painting it at my storage unit due to having to cover everything up. I'll most likely paint it after work when the day it is completed and pick it up the following day after work. Then the fun begins.
Posted: March 13th, 2009, 10:55 am
by ARH
I was gonna that at least now you can get the 12 counterweight crank... but I guess not?
Looks good, tho!
