Re: Bodo's Build
Posted: October 2nd, 2010, 12:48 pm
				The muffler shop didn't tighten up the exhaust clamps enough so that was the exhaust leak.  Score another one for me.
Valve noise is fine except for one troubling thing. I detect a slight clack at higher RPM. Not there when the engine is cold, but more noticeable after everything is warmed up. My well-tuned ears have narrowed it to somewhere in the back 1/4 of the valve cover.
Going to pull the valve cover tomorrow after work. It's either a loose rocker bolt, collapsing lifter or the dreaded cam lobe wipe.
I'll check the bolts again and then put a dial gauge on the rockers.
please let it be a rocker bolt.....
