Page 3 of 10
				Re: new stroker build, some issues
				Posted: January 7th, 2014, 4:42 pm
				It will take a few moments for the lifter to bleed down. I would wait until it stops then take the reading.
				Posted: January 7th, 2014, 4:48 pm
				by danimal
				but if the lifter has to bleed down for the valve to close, how is the valve actually closing at all while it's running?
				Posted: January 7th, 2014, 4:57 pm
				It will bleed down then pretty much remain static while running. Constant pressure from the valve will keep the lifter cup in the correct location.
				Posted: January 7th, 2014, 5:25 pm
				by danimal
				ok cool then it's probably ok. Well i guess ignition is the next step, unless anyone has a better idea.
				Posted: January 7th, 2014, 5:40 pm
				by sly-jeeper
				did you check pre load on all cylinders? its most likely not fuel related if running rich didn't change it, how many miles are on it? did you break in the cam properly? im almost positive its  either valvetrain or ignition
				Posted: January 7th, 2014, 5:43 pm
				by danimal
				no i didnt. it got dark out before i could, i only checked a few. There's about 15 miles on it maybe? drove it across town to use the smoke machine. Yes i broke the cam in properly.
I'll check all the preload tomorrow i guess.
Thanks for the help guys!
				Posted: January 7th, 2014, 5:53 pm
				I would not rule out fuel related issues yet. The PCM can do funny things if the fuel injectors don't agree with it or with the engine needs. If you have a known good set of stock ones it wouldn't hurt to throw them in a drive it gently to rule out the injectors. Salvage yard injectors always scare me also. Also, check your fuel pressure.
But as said, check preload on every cylinder. Remember it may take more time than a few seconds for the lifters to bleed down.
				Posted: January 7th, 2014, 6:19 pm
				by sly-jeeper
				yea jeep pcm's are something  of there own kinda like women...and idk about you but it's colder than a well diggers ass here
				Posted: January 7th, 2014, 6:22 pm
				by danimal
				well ill consider swapping out the injectors if it continues. tomorrow i will check preload and the ignition system. might grab a distributor from the jy and a spare injector if the truck i got them from is still there.
				Posted: January 7th, 2014, 6:26 pm
				by danimal
				sly-jeeper wrote:yea jeep pcm's are something  of there own kinda like women...and idk about you but it's colder than a well diggers ass here
thankfully it's in the 70's or 80's here lately so working on the heep hasnt been too bad.
				Posted: January 7th, 2014, 6:30 pm
				by sly-jeeper
				danimal wrote:sly-jeeper wrote:yea jeep pcm's are something  of there own kinda like women...and idk about you but it's colder than a well diggers ass here
I would have a heat stroke! I just did a motor swap on a IH h tractor today and it was -5 f in my garage
				Posted: January 7th, 2014, 6:35 pm
				sly-jeeper wrote:and idk about you but it's colder than a well diggers ass here
Yeah.. it was -10 here this morning and got to a scorching 15* max during the day... no way in hell I would be doing any engine work in that weather.
				Posted: January 7th, 2014, 7:01 pm
				by Flash
				Even though you have index the dist, you my need to grind the ear of the dist so that you can fin tune the timing. (twist it back and forth slightly)
I don't know what year 4.0L you have, but my old Renix(89) ran much better after i did this.
				Posted: January 7th, 2014, 9:14 pm
				by 6TIME
				Ditto on checking your lifter preload. Do you know how far you sunk the valves into the head? If you took .035" off the deck and then took more from the valve seat to increase spring install ht., this combination of things makes your pushrods act much longer (assuming you used stock ones?). This could possibly be maxing your lifter preload out, holding the valves open while it's running.
				Posted: January 7th, 2014, 9:50 pm
				by the grey ghost
				Could have two spark plug wires switched on the distributor, check 2 and 4, I did this once and kicked myself later
