Page 3 of 3
Re: Help with Golen 4.6L engine knock
Posted: November 18th, 2012, 3:38 am
by ossme
Thank you for the replay .. :)
The o2 sensors are connected properly.
I verified the fuel pressure and it stays at 49PSI at all times.
About the compression ratio, I didn't receive a build sheet so I don't know much about it. I can pull timing by the FIC.
I checked for intake leaks 4 times and found nothing. I get 13~14 Miles to the gallon. How much should I expect if I had an intake leak?
I face no other Error codes.
I will be removing the old AFR Setup and replacing it with Innovative LM-2 Logger today. I will be posting some results hopefully before the end of this week.
Posted: November 18th, 2012, 3:46 am
by ossme
I'm planning to do a normal drive and WOT Log. Other than AFR & RPM, what other things that I should log ?? :?:
Posted: November 18th, 2012, 7:39 am
by Cheromaniac
ossme wrote:When I'm accelerating, I'm hearing a hissing noise. I'm using K&N Filter. I don't know if this is normal for a stroker or not.
A hissing sound upon acceleration is normal if you have a big K&N conical filter. It's just sucking in a lot of air.
Your 13-14mpg isn't unusual for a brick on stilts wearing big boots.
ossme wrote:I'm planning to do a normal drive and WOT Log. Other than AFR & RPM, what other things that I should log ??
MAP & TPS voltages would be helpful.
Posted: November 18th, 2012, 10:41 pm
by ossme
Thanks ! :)
The MPG is actually better than similarly built trucks. Searching the other forums, I found that most are reporting 11~12MPG range.
Posted: November 20th, 2012, 6:51 am
by ossme
During the Installation of the Innovative LM2 Logger today. I found the following Check engine Error:
P0441
"Evap. Emission System Incorrect Purge Flow"
:huh:
Posted: November 24th, 2012, 10:37 pm
by ossme
ossme wrote:During the Installation of the Innovative LM2 Logger today. I found the following Check engine Error:
P0441
:huh:
The error did not come again after reset. Maybe, the fuel tank was over filled ?? :huh:
Posted: November 28th, 2012, 8:54 pm
by ossme
Sorry for the delay guys,
Ryan was helping me out in determining if SCT tuners would work with my Jeep. Unfortunately, it appears that my old bucket is not supported. :(
Therefore, I have to relay again on the FIC 8. :|
I will do the following this weekend:
1- Calibrate the Innovative logger.
2- Get the current FIC 8 Configuration.
Posted: December 3rd, 2012, 12:54 pm
by superstingray77
What model jeep is this? My 99 WJ had a leak into the purge control valve which was hidden behind the driver headlight. its just a slow code to reset but will cause a vac leak and toss the MAP readings off a bit making tuning properly impossible.
Check those little vac tite elbows, they look fine but more often than not are turned to mush and have holes in them.
Posted: January 16th, 2013, 7:28 am
by ossme
superstingray77 wrote:What model jeep is this? My 99 WJ had a leak into the purge control valve which was hidden behind the driver headlight. its just a slow code to reset but will cause a vac leak and toss the MAP readings off a bit making tuning properly impossible.
Thanks .. The jeep is 1998. I think I should get a diagram for the whole vac and test from there. :?
