Re: Keep blowing heads, dumping coolant.
Posted: April 12th, 2014, 6:00 am
My thoughts exactly.woodjeep wrote:you think you would have seen coolant pouring from the front of the motor if only loose bolts
Jeep - AMC 4.0L and 4.2L Stroker Enthusiasts
https://www.jeepstrokers.com/forum/
it wasn't pouring, but it was hissing out from the back of the pump, so i replaced the pump. already had the new one when i noticed the loose bolts, figured i'd use it anywya.woodjeep wrote:you think you would have seen coolant pouring from the front of the motor if only loose bolts
