Re: Stroker suggestion
Posted: February 28th, 2014, 6:16 am
Can anyone answer those questions
Jeep - AMC 4.0L and 4.2L Stroker Enthusiasts
https://www.jeepstrokers.com/forum/
You might be able to if the bore is in great shape. Mine was hardly worn, still had crosshatch and the ridge was so small I could push the pistons out. It is not a great idea though as the pistons will be a bit loose and could slap and make noise they also just won't seal as well. Boring it 0.020 over will give you a little more power from the increased displacement as a result of the slightly bigger pistons but not enough you will notice.2fst4you wrote:Could I just get it honed then reuse the pistons or get new OEM pistons?
Will boring it slightly over with new (larger) pistons but retaining my crank and rods give me any more power?
Your questions were already answered by a few people. Reusing the stock bore with that mileage is the half-assed way to do it.2fst4you wrote:Can anyone answer those questions
