Re: Map adjuster.. Feeling kinda dumb..
Posted: September 24th, 2012, 8:32 am
? So to use this, at WOT you have to 'flip' a switch? Really?
Jeep - AMC 4.0L and 4.2L Stroker Enthusiasts
https://www.jeepstrokers.com/forum/
The 12 volts comes from a "switched" source meaning one that is only on when the ignition is on.CobraMarty wrote:? So to use this, at WOT you have to 'flip' a switch? Really?
Oh ok.. makes sense. I cant find a good 12v spot now. Anyone have any thoughts????CobraMarty wrote:Mine does the same thing. Everyone says 5.0v but it really gets 5.13v. I think that is so that if the ecu gets that high volt back the it throws a CEL and a 'bad MAP' sensor. If you turn on the key with the map plugged in, the signal v will be like IIRC 4.67-4.73v depending on your altitude.
Probably a normal slight variation so don't sweat it. Even my own stock MAP reference voltage was 5.05v.showtime3492 wrote:I am reading 5.13 volts off the map supply without any modifications all i did was unplug the map and it is reading with the key in the on position 5.13 volts... Anyone know why this is?
OK, you're looking for a 12v feed that's only live when you have the ignition in the on position. The best one in the engine bay that you can tap into is the 12v wire to the electric fan relay.showtime3492 wrote:I cant find a good 12v spot now. Anyone have any thoughts????
Ok i guess i should go track the wires form the electric fan relay. I was trying to follow what some other people had done and said there were switched 12v plugs there and just didnt see them as viable.Cheromaniac wrote:Probably a normal slight variation so don't sweat it. Even my own stock MAP reference voltage was 5.05v.showtime3492 wrote:I am reading 5.13 volts off the map supply without any modifications all i did was unplug the map and it is reading with the key in the on position 5.13 volts... Anyone know why this is?
When people say use a 12v switched source, what they mean is a wire that has 12v supply ONLY when the IGNITION SWITCH is in the on position. Hope that helps you understand some of the terminology.showtime3492 wrote:I was trying to follow what some other people had done and said there were switched 12v plugs there and just didnt see them as viable.
Cheromaniac wrote:When people say use a 12v switched source, what they mean is a wire that has 12v supply ONLY when the IGNITION SWITCH is in the on position. Hope that helps you understand some of the terminology.showtime3492 wrote:I was trying to follow what some other people had done and said there were switched 12v plugs there and just didnt see them as viable.
The switched 12v wire that goes into the fan relay (fairly sure it's terminal 87 of the relay) is as good as any to tap into.showtime3492 wrote:One more question is it best to tap into the fan relay wires right under the power dist center or elsewhere?
Cheromaniac wrote:The switched 12v wire that goes into the fan relay (fairly sure it's terminal 87 of the relay) is as good as any to tap into.showtime3492 wrote:One more question is it best to tap into the fan relay wires right under the power dist center or elsewhere?
Glad you got it working.showtime3492 wrote:I got it installed and working properly. Thanks to everyone for the information. This is an awesome forum.
