Page 2 of 2
Re: Tune with Split Second
Posted: June 22nd, 2012, 12:58 pm
by montelibre
Some pics:
Currently, the pulely is smoller than in the pics.
http://www.jeepstrokers.com/forum/viewt ... f=5&t=2173
Posted: May 22nd, 2018, 7:14 pm
by Wenrickt
montelibre wrote: ↑June 21st, 2012, 2:19 pm Now I have got 12,5/1 AFR at WOT with current maximum boost (5 psi) and 30 lbs/hr injectors. :banana:
This is the map:
5 Psi 30lb-hr 23-03-2012.mdb
Thanks you all again.
Hey man is there anyway you can send me the map you ended up using I’m having struggles running the same set up
Posted: October 30th, 2018, 12:14 pm
by the grey ghost
Yeah I'd like to take a look at it too
Posted: October 30th, 2018, 2:05 pm
by RedTurboJeep
Hey guys I'm new to the forum I just bought a boosted crate from Golen engines it's a 4.0 stroked to a 4.6 liter it's got scat4340 forge rods& pistons HO head a cam from comp cams are head bolts and I'm using a Garrett 50mm turbo , a 38mm tial wastegate on 8lb tune from split second ....... I guess my questions is are there any other tuners that work like a standalone that don't integrate with the pcm to trick the stock brain into thinking there's no boost running through the jeep are there any real ecu for boosted application's and there any upgrades I can do to the engine regarding intakes ect
Posted: October 31st, 2018, 1:10 pm
by Cummins90
Ryan may be able to help you
https://www.frptuning.com
Or Kevin possibly
https://sykedecutuning.com/store/index.php
Neither one does canned tunes (prebuilt tunes) all need to be datalogged and built individually.
I am running an AEM FIC 1913. The whole experience got better once I got the injector dead time and map clamp dialed in.
Posted: December 18th, 2019, 9:29 pm
by mpampismykonos
Hello . i have a tj4.0 with supercharger, split second ftc 202, is there any map that can work properly? i have the split second map 2) For 6 psi amplifiers and 30lb FTC1-019 6lb base map.mdb injector.
Posted: May 24th, 2020, 9:19 am
by Bguse1983
montelibre wrote: ↑June 22nd, 2012, 12:58 pm Some pics:
Do you still have the ss tune?
Would you mind sharing it with me?
Posted: May 25th, 2020, 4:15 am
by Cheromaniac
Good luck getting a response 8 years since his previous post. :lol:
Posted: May 25th, 2020, 10:09 am
by Cummins90
Start a new thread and post up what you have so far. Someone may be able to help you out. Details about your engine will help as well.
Posted: October 18th, 2020, 12:48 pm
by Jroch99
Any chance of posting that map again ?
Posted: October 19th, 2020, 6:16 pm
by Mike B
Jroch99 wrote: ↑October 18th, 2020, 12:48 pm Any chance of posting that map again ?
Check the dates on the original post bud, not to mention the guys above ya just stated its an 8 year old thread. Chances of this guy responding are next to zero, but there have been suggestions made as to who may help ya. Look up a few posts....
