Page 2 of 2
Re: QUESTIONS ON A 98 TJ 4.6 STROKER
Posted: August 3rd, 2008, 6:28 pm
by John
What SilverXJ said and disregard the headers heating up for now, pretty normal.
Posted: August 3rd, 2008, 6:47 pm
http://www.youtube.com/watch?v=1CeuA6MuedA
A bit off topic, but notice the shot at the end... glowing down pipe... awesome video though.. had to post it.
Posted: August 3rd, 2008, 7:04 pm
by heartlandoffroad
Chris,
I looked at the link that you posted for me and that is the way that I do it and yes I did have to cut the ears off the distributor to get it to line up correctly.
Garrett
Posted: August 3rd, 2008, 7:22 pm
Then we can eliminate the distributor as the problem.
How did you put an adjustable fuel pressure regulator on it?
Posted: August 3rd, 2008, 7:34 pm
by heartlandoffroad
I put bulk head fittings in the tank put a Airtex rail pump on and a Aero Motive adj FPR in line and returned back to the tank. All 3/8 braided line. Capped off the stock pump and regulator and left in place.
Posted: August 3rd, 2008, 7:40 pm
Ahhh... interesting way around the in tank regulator and filter. What is the fuel pressure now?
Posted: August 3rd, 2008, 7:54 pm
by heartlandoffroad
49lbs
Posted: August 14th, 2008, 8:35 pm
by heartlandoffroad
We finally got this thing figured out. The builder didn't put the rite valve springs on it ( still had the stock springs on it). Runs great now.
Posted: August 15th, 2008, 9:27 am
by John
Glad you ran this aground. Built in mechanical rev limiter. Did they reuse the old springs, what did you install?
Posted: August 15th, 2008, 3:42 pm
by heartlandoffroad
Yes they did reuse the stock ones.
I used Comp Cams 926-12 Springs, 744-123 Retainers, 603-1260 Locks
Posted: August 17th, 2008, 11:23 am
by seanyb505
Good info to know, my machine shop advised against installing 5.9 springs and so we just reused my stock ones, for break-in at least.
Posted: August 17th, 2008, 11:50 am
by jeepinwi
Very interesting thread. I'm running a Crane 753905 cam with stock valve springs, and it pulls strong up to 4800 rpm's. After that, it seems to make more engine noise than thrust.
Posted: August 18th, 2008, 10:24 am
by Cheromaniac
Your stock exhaust could be one reason why your engine feels sluggish above 4800rpm. Another could be the stock valve springs causing valve float.
Posted: October 31st, 2008, 7:28 am
by Sighman
heartlandoffroad wrote:We finally got this thing figured out. The builder didn't put the rite valve springs on it ( still had the stock springs on it). Runs great now.
Good job on hunting this down, I need to have a friend like you!!!!!!
