Page 2 of 3
Re: Preferred Stroker Plugs
Posted: April 15th, 2008, 9:52 am
by Comanche91
FrankZ wrote:I run Bosch Platinum 4's. I tried the xtock Champions and got alot of noise on my stereo and CB...weird but true.
I had a lot of noise also on my stock 91 AM/FM/Cassette player too, but swapped in a single DIN Mitsubishi AM/FM/CD player in it's place and no more static. Must be filtered better.
Posted: June 23rd, 2008, 8:25 pm
Has anyone tried an E3 spark plug yet? Looks ours would tale the E3.64 Champion RC9YC crossover).
-Chris
Posted: June 23rd, 2008, 8:40 pm
by amcinstaller
i have never seen E3s around. my favourite local partsman is starting to think theyre a myth
Posted: June 24th, 2008, 6:02 am
Advanced sells them over here.
Posted: June 24th, 2008, 5:46 pm
by amcinstaller
where is here? im in canada, and i think ive seen them on tv......once.
Posted: June 24th, 2008, 7:55 pm
Virginia
Posted: June 25th, 2008, 12:00 pm
by rkcrwlr
FWIW, Golen calls for Autolite 985s gapped 0.040 in thier strokers.
Posted: November 22nd, 2008, 2:03 pm
by crustodd
What happens if you're running an after market ignition? I have a full MSD set up (overkill?) It fires triple the normal rate below 3K. Suggestions?
Posted: November 22nd, 2008, 2:42 pm
by John
What does MSD recommend?
Posted: November 22nd, 2008, 8:12 pm
by crustodd
I haven't checked with MSD. Didn't think of it.
Posted: November 23rd, 2008, 5:16 am
by Mgardiner1
Does your MSD box allow you to adjust ignition timing? I know not all ignition boxes are capable of that, some just make a hotter spark
Posted: November 23rd, 2008, 8:24 pm
by crustodd
My MSD box does allow for that, but I didn't get the controller for it as I didn't think i'd be using it to that extent. I know, OVERKILL! Maybe with a stroker, it will be of some advantage.
Posted: February 6th, 2009, 1:34 pm
by daccarettfletez
I'm also running an Msd 6 in my 4.0 with a firepower coil, summitracing 8mm cables and been using the accel yellow u groove plugs (any good?) gapped at .45, My engine is torn down in the process of becomiing a 4.5 poor man's stroker (4.2 rods, crank, 4.0 pistons dished to 23cc, no overbore, no decking, victor reinz head gasket, at sea level) do you think they will still work or should I switch to the champion rc9 or rc10 plugs?
Posted: February 6th, 2009, 2:04 pm
by Comanche91
I've tried NGKs, Bosche, Champion "Truck" plugs, etc. ad nauseaum. Nothing works better for me than the old school RC9 or RC10 copper cores. They are recommended both by Mopar and Hesco for the OBDI NA and strokers; I'm stickin' with them.
Posted: February 6th, 2009, 11:58 pm
by gradon
I have the rc9s in mine. I loved the Autolites double plats on my 4.0.
