Calculator...
- Mgardiner1
Re: Calculator...
i'll look into it. I am always very current with my updates
- Mgardiner1
Re: Calculator...
OK, running the latest java update has cured the problem Win 7 and IE 8 functionality is a go.
- Muad'Dib
Re: Calculator...
I went ahead and implemented the above change. This helps you know what cam you have selected when you calculate your results. When you enter your own custom numbers, then it will say "No Selection".Muad'Dib wrote:I may have a text area that gets populated with the cam manufacturer, and model number of the cam that you select.
This new feature is also nice for when you "Print screen", or physically print out the calculated results. Then you can see what cam you actually selected to get your numbers.
- Muad'Dib
Re: Calculator...
Thank you.Mgardiner1 wrote:OK, running the latest java update has cured the problem Win 7 and IE 8 functionality is a go.
Bodo
Re: Calculator...
Working as advertised. Thanks!
lafrad
Re: Calculator...
Looks like the isky cams are off...
According to their catalog, they are 111, 110, 109, and only a couple 108 LSA cams...
http://www.iskycams.com/onlinecatalog.html
- PolloLoco
Re: Calculator...
So I first selected my cam to check it out and the text boxes appeared, cool! Then I went to enter my other data in the top section and the boxes dissapeared, not cool. Then when I hit calculate the boxes appeared with "No Selection."Muad'Dib wrote:This new feature is also nice for when you "Print screen", or physically print out the calculated results. Then you can see what cam you actually selected to get your numbers.
Windows Vista x64
Firefox 3.0.8
Javascript enabled, popup appears in new window, window self-closes
Re: Calculator...
According to Isky's timing charts the numbers on the calculator are correct. The AMC listing in their catalog differs from the timing charts. I don't know which is correct, but I went with the timing charts and not the catalog.
Parts #; Duration; LSA; Timing chart link
1331M; 248; 108; http://iskycams.com/timingchart.php?pro ... ber=1331-M
133125/26; 256; 110; http://iskycams.com/timingchart.php?pro ... =133125/26
133126; 262; 108; http://iskycams.com/timingchart.php?pro ... ber=133126
133127; 270; 109; http://iskycams.com/timingchart.php?pro ... ber=133127
133128; 280; 109; http://iskycams.com/timingchart.php?pro ... ber=133128
- Muad'Dib
Re: Calculator...
I know whats causing this. Thanks for reporting. I am working on it right now.PolloLoco wrote:So I first selected my cam to check it out and the text boxes appeared, cool! Then I went to enter my other data in the top section and the boxes dissapeared, not cool. Then when I hit calculate the boxes appeared with "No Selection."Muad'Dib wrote:This new feature is also nice for when you "Print screen", or physically print out the calculated results. Then you can see what cam you actually selected to get your numbers.
Windows Vista x64
Firefox 3.0.8
- Muad'Dib
Re: Calculator...
Done .. fixed. Thanks for the report Polloloco.
- laxplayermjd
Re: Calculator...
Hey i think it'd be a good addition to add the mopar performance cam thats still available.
BMW Master Tech
ASE Master Tech
Even BMW guys need a toy.
In process 4.6l Renix Build.
ASE Master Tech
- Muad'Dib
Re: Calculator...
If someone has the information on it, i can add it into the calculator no problem.laxplayermjd wrote:Hey i think it'd be a good addition to add the mopar performance cam thats still available.
- Muad'Dib
Re: Calculator...
I made another addition to the calculator today.
Next to the "Calculate!" button there is now a "Print View" button. This can be used to have a nice neat printable view of your results.
As always, let me know if there are any problems.
- laxplayermjd
Re: Calculator...
Mopar Performance Cam
Part Number : 4529228AB
Advertised Duration: 240 int./240 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.430 int./0.430 exh. lift
Lobe Separation (degrees): 108
Overlap 24
That is really all i could find for it.
Overlap 24
BMW Master Tech
ASE Master Tech
ASE Master Tech
yuppiexj
Re: Calculator...
Valve event timinglaxplayermjd wrote:Mopar Performance Cam
Overlap 24
Intake Opens 12 BTDC
Intake Closes 48 ATDC
Exhaust Opens 48 BTDC
Exhaust Closes 12 ATDC
