Does anyone know why the 707 rods are better than the 352? I picked up a set of 352s and then did some checking on numbers after(bass-ackward just like usual. This is why my projects cost twice what they should ).
I plan on putting ARP bolts in and re-sizing big end.
I am not building a race engine , but if the 707s are really better, I'll sell these and find a set.
Thanks for any info
Paul
258 con rod numbers (707 vs 352)
- Vehicle Model: WJ
"It's not what you buy, it's what you build"
03 Grand Cherokee
JK axle swap
5" lift
STROKER IN PROGRESS
03 Grand Cherokee
JK axle swap
5" lift
STROKER IN PROGRESS
Re: 258 con rod numbers (707 vs 352)
No idea why people say the 707's are better. I got a set of 352's that I polished and shot peened. I don't see a problem with running them. If you sell your 352's let me know.
- IH 392
707's are more common, I don't think that I've ever even seen a set of 352's?, just like the 12 CW cranks are more common, I think I've seen two that didn't have full counter weights???
The 707's are reputedly stronger but the 352's look exactly the same and weigh the same so I see no reason why you shouldn't use them. You can even mix the two (I have four 707's and two 352's in my 52k mile old stroker). I definitely recommend new ARP rod bolts and it would be a good idea to polish the rod beams, resize the big ends, make sure they're weight-matched, and have them shot peened.
