JeepStrokers.com Decal \ Window Sticker
- Muad'Dib
Thanks to SilverXJ we have made some progress on our decal / window sticker design.
Here are the ones i thought were the best:
As you can see they are numbered 1-9.
Please choose which design you like the best. Optionally you can select your second favorite just in case i decide to have multiple designs produced.
Please vote, and it would help if you provided / posted feedback!
Thanks very much for your participation.
- Mgardiner1
Re: JeepStrokers.com Decal \ Window Sticker
My first pick was #6, i like the border of the gear, makes it look well balanced and clean.
My second pick was #1, because its plain and simple.
oletshot wrote:....and silvolites are only cast not hypericantspellits.
I personally like #7 the best. Shows the single most important part of the stroker engine, the crank,front and center and incorporates the piston in to it... but doesn't have too much extraneous items.
- seanyb505
- Stroker Displacement: 280ci
x2 on #7. Shows the crank, and incorporates the piston and rod assembly into the words. Im guessing #4 has only a bigger font than #1, so it also gets a thumbs up. You want people to be able to read it without tailgating. I like 7 the best.
97 XJ 4.6
90 MJ 4.0 - sold
97 XJ 4.6
90 MJ 4.0 - sold
- Mgardiner1
I didn't vote for #7 cause i think it just tries to "cram" 10 lbs of sh*t into a 1 lbs bag. It looks more like an earing hanging off of the "T"
- Flash
I like #6 the best and 2nt chose would be #9
I thing that if #5 had the piston turned and attached to the crank, and then made part of the "T" that might be cool.
I agree that #7 look more like a ear ring then a rod.
I realize that #7 doesn't have the crank in the pic..........which i thing is important............But 6 and 9 was the ones that jump out and grabbed me!!!
Flash
Flash
I didn't vote yet, but agree with what Flash said with turning the piston/attaching the rod to the crank and incorporating it with the t in strokers on #5(why #7 looks good), but I'd want the gear around it like #6. From design 6's perspective, make the x into a t with the crankshaft horizontal and then 90 the rod onto the crank and make it smaller/scale to correct size of crank(but still will be a big t) and put it b/t the s and r.
I thought about attaching the piston to the crank, but depending on which one you looked at the new 'T' would either be too big, or the piston would be just to small to be noticeable in others.gradon wrote:I didn't vote yet, but agree with what Flash said with turning the piston/attaching the rod to the crank and incorporating it with the t in strokers on #5(why #7 looks good), but I'd want the gear around it like #6. From design 6's perspective, make the x into a t with the crankshaft horizontal and then 90 the rod onto the crank and make it smaller/scale to correct size of crank(but still will be a big t) and put it b/t the s and r.
- Jeep-Power
- Stroker Displacement: 4.3
- Vehicle Year: 1984
- Vehicle Make: AMC/Jeep
- Vehicle Model: CJ-7
#3 & #8 look identical to me... I like them
I also like #6 alot-- can the gear be made a little less 'visually heavy'?
-- TallPeter
'84 CJ-7 - tonned & turbo'd
- FrankZ
- Stroker Displacement: 4.6l
Maybe it's just me, but they all seem redundant. JeepStrokers/JeepStrokers.com...?
How about something a little more catchy?
"I got Bored at JeepStrokers.com"
"Ask me about my enhanced stroke! JeepStrokers.com"
"It's the cubes that matter. JeepStrokers.com"
"Build it bigger, build it better. JeepStrokers.com"
"Yeah I Supersized it! JeepStrokers.com"
- Muad'Dib
FrankZ wrote:Maybe it's just me, but they all seem redundant. JeepStrokers/JeepStrokers.com...?
Thanks very much for these suggestions.
I really like these ideas. Once we decide on which logo to go with, we may use one of these catchy sayings as long as that is ok with you.
- FrankZ
Damnit! Should asked for some coin up front!
Can I get a free sticker at least?
- Muad'Dib
Yes of course if i decide to follow that ideaFrankZ wrote:Damnit! Should asked for some coin up front!
- FrankZ
Yippie
Free for me! free for me!!
Sure you can use them and I don't even need the free sticker.
Users browsing this forum: No registered users and 24 guests
