Calculator...
- Muad'Dib
Re: Calculator...
Still can work on it. I just need to specs of the cams to add.
- Muad'Dib
Re: Calculator...
I did a logic check on the Calculator today since it's been forever since I did all that work.
I found an issue with how we calculate DCR at Altitude. The old calculation used a simple linear formula (subtract 0.2 DCR per 1000 ft) which worked okay at lower elevations but became increasingly inaccurate the higher you go.
The Problem:
At higher altitudes like Denver (5,280 ft) or Flagstaff (7,000 ft), the old formula was actually over-correcting - making your effective DCR appear higher than it really is.
The Fix:
Updated to use the standard atmospheric pressure formula (same one used in aviation/aerospace). This accurately calculates how air pressure drops with altitude and applies it correctly to your DCR.
Bottom line: The calculator will now give you more accurate numbers, especially if you're at altitude.
The Problem:
The Fix:
cal
- Stroker Displacement: 4.71
Re: Calculator...
oooh exciting!
Considered adding the newcomber roller cams?
https://www.newcomerracing.com/store/p4 ... p_AMC.html
- Muad'Dib
Re: Calculator...
I made more improvements today:
- "N/A" Display for Missing Cam Data
- Auto-Calculate on Input. No need to hit Calculate button.
- Reset to Defaults Button
- Muad'Dib
Re: Calculator...
I added the cams listed on their page. None of them appear to use any Advance\Retard .. or at least its not listed.cal wrote: ↑January 13th, 2026, 10:56 am oooh exciting!
The calculator also has some other minor fixes.
FYI I am in the process of a redesign of the calculator page so stay tuned!
- Muad'Dib
Re: Calculator...
Actually you might want to hold on the Newcomer Racing cams for now. From what I am finding they don't appear to publish Advertised duration.. only at 0.050 which will not work for our calculations. We might need to remove these unless I can find other data.
- Muad'Dib
Re: Calculator...
Closing this thread to start a new one for the re-design.
