Forum Maintenance 8-18-8
Check here for most things forum related... NOT stroker related!
Locked
I will be doing some forum maintenance tomorrow sometime probably between 8am-12pm PST... depending on how busy i get at work.
I will be updating our version of phpbb, adding some features, and cleaning up some code.
While im doing this, the forum will be closed. Once i actually start, it should only take about an hour for me to finish. This all depends on if i get pulled away or not.
This is a "heads up" just in case you try to access the forum tomorrow and you get a message about the board being disabled. Keep checking back though... it wont be down for to long!
Thanks!
Re: Forum Maintenance 8-18-8
Well i got slammed today at work, so i wont get a chance to do this... I changed the date to monday, i hopefully will be able to get it done then..
Thanks!
Ok, all finished... It all ended up taking about 2 hours...
Everything is now up-to-date, and alot of my own "coding" has been cleaned up to hopefully make the board run smoother / better.
Please let me know if you have any comments or questions!
Thanks again for your patience!!!
Topic closed .. seems to not have been an issue for anyone!
Locked
