my long drawn out street/strip xj build
- vashxj
Re: my long drawn out street/strip xj build
I just built the 4.6 low buck with 30 over icon pistons, 4wt crank, and 231 comp cam. I only added a few extras to the blueprint. I ported a 7120 head and used stainless 1.56 exhaust valves, ceramic header, hs rockers, and 3.0 ford Taurus injectors. my compression should be 9.6. the n2o kit I believe it zex 82021 its a v8 kit
What do you mean you added something to the blueprint?vashxj wrote:I only added a few extras to the blueprint.
- vashxj
my engine is the same as 4.6 low buck except icon pistons (same company) 1.56 ex valves (which isn't much), hs rockers, header, 2.5 exhaust, bored tb, and ford 3.0 injectors
- Vehicle Year: 1994
not much different than what im planning then...
- vashxj
just found out last night my friend ordered his new s/c for his mustang so I should be getting his old one from him soon, don't think ill get to installing it this year though still getting all my trans stull together and I need new windows on the house lol
- vashxj
starting on swapping gears, installing pedals, clutch master and removed the hitch, got the slicks mounted
- vashxj
got the pedals switched, installed clutch master and 4x4 hole covered up
- vashxj
pretty much done took it out for a few cruises and holy crap at the torque it has now
- Vehicle Year: 1995
- Vehicle Make: ZJ
- Vehicle Model: Laredo
I just love looking at your street machine. Sweet ride and sounding even more like the performer it appears to be.
Let us know the next track times you lay down. Looking forward to hearing/reading it!
Don't use those 3M scotch locks on any surface that needs to be flat. Cylinder head, block deck, brake rotors, clutch surfaces, etc. They do way more damage than good. Not to mention the abrasive crap they throw off into cylinders.
- vashxj
I know what your talking about silver, I just used a surface prep one I had after I machined the flywheel to clean up some surface rust. I do use them a lot at work, haven't had any problems yet but I heard some guys did. guess its just how hard you push
even the surface prep ones damage the surface. Many use them and many blocks and heads need to be resurfaced because of them.
- vashxj
a little update........... got the speedometer working, didn't notice the speed sensor is offset. just have to switch out the oil pressure sensor to a 2 wire one and finish up the front axle. also going to pick the s/c up next week. just need to get injectors, intercooler another intake and tb
- vashxj
went to the track sat and blew up the spider gears lol, I have started gathering supplies to build a ford 8.8
- Stroker Displacement: 4.2l
Just go 9" I regret it every time I did my 8.8. Non-c-clip is a huge plus, even a 28 spline is slightly stronger than the 8.8 from specs I've seen. Disk are easy to swap from an explorer.
And the biggest plus? Drop out 3rds...maybe 3.55 for daily and 4.10s for track
Users browsing this forum: No registered users and 27 guests
