MAP Adjuster Build Issues
NelsonATC
- Vehicle Year: 1980
- Vehicle Model: CJ7
I am building a MAP adjuster according to Dino's instructions, and am having issues. It will only let me fluctuate voltage between 7.8 and 8.1. I originally thought the trim pot was bad, but I replaced it with the same issue. Then I swapped out the voltage adjuster, still the same. The resistor checks out, so now I'm at a loss to figure out the issue. Has anyone else had this issue while building a MAP adjuster, and if so, what fixed it?
Thanks!
Mike
Thanks!
Mike
Re: MAP Adjuster Build Issues
Sounds like something's wrong with the way you've built your MAP adjuster. Check it against my schematic:
If you elected not to wire an SPDT toggle switch into your system, here's what the schematic should look like:
NelsonATC
Matches perfectly. Still not working
jbxx
- Stroker Displacement: $.6 mistake?
- Vehicle Year: 1986
What value trim pot ( 1K ohm ), and what # regulator ( LM317)?
Make sure you get in, out, and grd. correct compare to data sheet. Not much else can go wrong.
J.B.
LM317 datasheet:
http://www.ee.buffalo.edu/courses/elab/LM117.pdf
J.B.
LM317 datasheet:
jbxx
Picture of completed circuit please.
J.B.
J.B.
NelsonATC
All components are to spec. Set up according to schematic, Replaced both trimpot and voltage regulator. Same issue
The only other thing I can think of is that the fixed resistor might not be 220ohm.jbxx wrote:What value trim pot ( 1K ohm ), and what # regulator ( LM317)?
J.B.
LM317 datasheet:
NelsonATC
Tested it. it checks out
- W_A_Watson_II
- Vehicle Year: 1993
- Vehicle Model: YJ
220 Ohm Resistor should be Red, Red, Brown, Gold. I see Red Red ? Brown.
NelsonATC
I will look when i get home, but I tested the resistor with a good multimeter and it checks out at 220.
NelsonATC
Red, Red, Yellow, Gold I Think I found my problem!
- W_A_Watson_II
- Vehicle Model: YJ
Yep, I think so.
Red, Red, Yellow, Gold is a 220kΩ 5% Resistor
Red, Red, Brown, Gold is a 220Ω 5% Resistor
NelsonATC
That was the issue. Thanks for the help! That's the last time I take the desk jockey's word at RS! Of course if I had my multimeter set correctly, I would have known earlier
FlyinRyan
Offtopic....Are you a controller?
Looks like you'll be buying a few beers.NelsonATC wrote:That was the issue. Thanks for the help!
