4.0 head holes for 4.2 block
- Vehicle Year: 1983
- Vehicle Model: CJ7
What would be the negative if any of having the unused water holes on the 4.0 head filled with aluminum? I have a welder that says it will bond just fine, but my dad says he does not think it will handle the heat. What do you guys think and also what have you done yourselfs. thanks
Re: 4.0 head holes for 4.2 block
It might work. Head won't be an issue for the aluminum. People have used JB weld in the past. If the welder can get the aluminum to bond and seal it should work. Don't know if that is possible though.
- Vehicle Model: xj
Shortstraw8 wrote:What would be the negative if any of having the unused water holes on the 4.0 head filled with aluminum? I have a welder that says it will bond just fine, but my dad says he does not think it will handle the heat. What do you guys think and also what have you done yourselfs. thanks
How do you fill a cast steel head with aluminum? Im a welder and im just sayin you cant weld steel to aluminum.
