what did you do for an air cleaner in your small-body AMC?
AMX's, Gremlins, Pacers, Ramblers, Eagles etc.
H.M.X
Where's the "any" key?
Post by H.M.X »
I've been entertaining several options for an air cleaner with my stroker in my small-body AMC but haven't come up with anything yet. Have you gone over the rocker arm cover (like a YJ/TJ) or down toward the radiator (like an XJ)?
dan
Shark
Consistent
Consistent
Re: what did you do for an air cleaner in your small-body AMC?
Post by Shark »
how much room you got?
'95 XJ 4door 4.0 aw4 2" 31's
H.M.X
Post by H.M.X »
not a lot, especially forward of the intake and exhaust.
Shark
Consistent
Consistent
Post by Shark »
got any pics?
H.M.X
Post by H.M.X »
a dark one, yeah:
Underneath the temporary air cleaner, you can see where I mounted the ECM on the shock tower. Forward of the ECM is the coolant recovery tank, then forward of that is the washer bottle. If I do go forward, it'd be a tight routing around the power steering pump. If I go over the rocker arm cover, there's hardly any space between the battery and the alternator to draw fresh air in.
dan
Shark
Consistent
Consistent
Post by Shark »
wow, you werent joking. that is a tight space.
1bolt
Post by 1bolt »
if a cowl induction hood isn't out of the question the firewall on the cool side of the engine is perfect and will give you as much as 6% increase in power (12 rwhp on a 200 wheel hp stroker) if you seal it to the cowl opening.
Simon
yuppiexj
Post by yuppiexj »
A guy I know in Richmond VA dropped a Renix 4.0 in a spirit and here's the custom air cleaner adapter he used and retained the stock air cleaner.
he has a nice swap gallery
http://www.picturetrail.com/gallery/vie ... =170246093
HTH
I'm digging for the CAD drawings he sent me for this piece.
amcinstaller
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Post by amcinstaller »
yea, these cars are frickin tight. im not sure on my spirit either actually, i was thinkin about a turbo and intercooler before which would have simplified things alot, but now im not so sure on turbo. how much room is there above the rear of the engine and under the hood on your car? and which car is it? i think i remember reading on another forum you have a 80's style amx, but i could be worng
