Which Oils/Additives contain ZDDP
Flash
Re: Which Oils/Additives contain ZDDP
Post by Flash »
OK, sence no one is going to touch this one.(23 have read it after my posting of it) here i go :!: :mrgreen:
The Pennsylvania Crude Myth was interesting and I can see how some thing, that was NO Myth at the time, keep going after the situation wasn't true, do to additive package, and better processes that made them Equal
Detergent oil Myth: I understand what happened, learned and can understand the fear (that was always beat into my head as a you kid)that my dad would tell me...........WHAT EVER BRAND OF OIL THE PREVIOU OWN USED! you HAD BETTER ALSO, OR IT WILL START USING OIL AND NEVER STOP!.....kind of understand why he would have said that and believed it and i still fallowed his thoughts.................Unless the previous own used Pennzoil! i would always us the brand of oil that they used......Have kinda fallen a way form this practice years back...........and especially sence this ZDDP has hit the scene!!!!!!!
The Synthetic oil Myth: Hmmm, Maybe I'm going to be one of them that keep the myth alive! BUT, I believe that almost all factory eng. are.........run in(semi broke in before they are shipped...."Just my opinion") and today rings, seat much quicker then the old.............remember CHROME rings.......took for "ever' to seat the Rings, created all kinds of heat in the cooling system.........but once you got them seated........You cylinder walls would wear out first!
IN my opinion, syn. will just cause the rings a longer time to seat in :huh:
Engine Oil Myth: Ha yes, the meat of the story!!!
Read the first paragraph........."Myth promoted by the antique and collector car press" Hmmm well i will leave that statement right there.
There own words, ZDP(ZDDP) was raised to 0.08 in the mid 50's because of valve and cam wear due to hi lift cams.
ZDDP was first added to oil to extend the life of rod and main bearing........sound like its good stuff to me.
Can we have to much of a good thing.........Yes according to test that were taken when ZDDP wasn't a liability!!!! over 0.14 it starts to head toward hindering instead of helping! and by 0.20 your creating or shortening the life of you eng! In other works, don't fill you crank case up with just bottles of the E.O.S! :D
One side note, E.O.S is what has all the ZDDP in it! GM also sell M.O.A which is not the same.....E.O.S is what you want!
they even say that a higher lever of ZDDP(0.14) is Good for flat tappets and valve train for scuff and wear!!!!!
They basically tell you that 0.10 was the perfect amount for any eng up to or until the era of the Cat!!!!!!
They say that ZDDP level have been slowly dropping over the past 10-15 years(they new were they were heading and the Flat tappet eng was not going to make it!!)
Now that there story is up to the days of the cat's............the first statement the grabs me, is there comparison to the 0.08 ZDDP that was good enough for the Hi lift cam in the 50's.........My first thought is the 50's 0.08 ZDDP was the MINIMAL, OR THE LEAST that the ZDDP could be at...............Now it's the "MAX" it can be at In other words, star burst oils (New oil formulas) rarely make it up to 0.08 for fear of going over the now illegal level for star burst oil!!!
Next, They "say" ........."that BackWards Computability was of grate important with the group of experts from the "OEM"s oil company's(I still wonder just exactly what the means????)
Now for the test of there Quote "Backwards Compatibility tests! :doh:
test #1 the over head cam that they make sure you know is NOT A ROLLER CAM/ ROCKER ARM ENG!!!!! Well OK, it is in fact not a roller cam YES. it is a cam "slide" follower type cam......kind of like a flat tappet cam..............seams like a fair test.......right?
test #2 a Flat Tappet V6 eng(they say) that is similar to the 80 vintage(does any on remember the lack lust gutless wonders of the 80's??????????
OK we now that from what we have read, in this article and what we have discuss in this form, that lift.......or spring pressure created by lift(hi lift) is what requires at least 0.08 to 0.10 ZDDP oil package.
I bet that if you have a oil sample of the oil that they use, it wouldn't be .0001 below the 0.08 star burst oil recipe!!!!!
Now, Test #1: Since it is and over head cam eng. It Need much less spring pressure for the same lift, due to the loss of push rods and lifters that would require more spring pressure to keep it on the lobe............Will this eng survive with 0.08 or less ZDDP
YES, THERE WOULD BE MUCH LESS SPRING PRESSURE THEN WOULD BE REQUIRE FOR A STOCK 4.0L
Test #2 Flat tappet V6 eng similar to the 80's vintage:...............would this be a High lift cam eng....NO, is this the cam lift even close to the so called HI lift of the mid 50's not even close.
So, yes GM was thing about it previous built eng(Backwards Computability)......as far back as there would possibly being a warrantable claim!!
Why didn't GM us a 3d test, a real test of like......Aammmm......lets say a 68 396 or or even one of those Hi reving small blocks of the day? Because the star burst oil is only as go as the oil that was made back in the 50's??????????????????????? :banghead:
They should have been testing the muscle car eng of the last 60 and eary 70's (this era they seam to avoid with most of the discussion......as there backward testing, was in no way tested at all!
Will our stock 4.0L survive on star burst oil????? I say YES
Will i back up my word and start using star burst oil in my 300,000 mile jeep NOW??????? NO!!!!! I say yes because the spring pressure would be vary close to that of the V6..................
Will a performance cam, 4.0 or stroker survive on star burst oil........ONLY AND I SAY ONLY!!!! if the cam don't require more pressure then the stock spring ......BUT remember even a stock spring will put more pressure on a lifter as the lift of the cam increases above the stock lift.
Final thought, GM is a flat tappet cam manufacture and has some of the highest standers of quality control of the industry( mostly because, most of what they made when into there product...............Makes you wonder how much longer they will be in the business, of making a product that they no longer us..............
In my opinion, this is far from a myth.............some day, when they find a proven additive that works a good as ZDDP and is a no ash or will not affect emission devices...........will this one become a REAL MYTH!!!!!!!!!!
My hot are is done ...........care to share yours? :?:
Flash
Post by John »
Ok, my rant. Like several of the politicians out there, this represents clearly, self serving, lying sack of shixxx. Amen
Post by John »
SAE specs 1200 ppm for zddp and the European societies specified even higher levels. Lets see....... "Even prior to the introduction of the API's SM standard, there was concern that current API SL standards from back in 2003 may inhibit the backwards compatibility of motor oils, specifically referring to the limitation of ZDDP, which is "the most effective combined anti-wear and anti-oxidant additives currently available." SAE 2003-01-1957, Effect of Oil Drain Interval on Crankcase Lubricant Quality, Shell Global Solutions. The authors continue to state that oils are required to provide longer protection in severe operation but that an oils performance is "limited by environmental considerations." Furthermore, they state that it is hard to predict the effects of these reformulated oils in just a single oil change and may only be evident over an engine's lifetime".
Oil manufactures were legislated to modify formulation, Automobile manufactures were legislated to super warranty catalytic converters. The new oils are fine for most of the new design motors, Kills motorcycles, marine engines, Porsche engines, Ferrari engines and most classic engines (like ours) But they still have to sell it. So we get a few Norm, from Cheers, factoids followed by a line of BS. But then it doesn't bother me...............
4point6
I think I'll order a "tab"
Post by 4point6 »
This was posted on the moparts forum, taken from some Porsche forum. A little long, but has some good info.
Name Vis P (ppm) Zn (ppm) B (ppm) Detergents (ppm) API Date Type Source
Amerilube 10w50 1254 1115 3001 SL 04/07 SYN Blackstone
Amsoil AFL Euro 5w40 701 804 50 1452 SL 11/06 SYN Staveley
Amsoil HDEO 5w40 794 1081 2276 CJ-4 11/06 SYN Staveley
Amsoil Series 2000 Racing 20w50 1014 1123 12 3209 SM 02/07 SYN Blackstone
Amsoil V-Twin/MC 20w50 1193 1281 3564 SJ 11/05 SYN Staveley
Amsoil XL-7500 5w20 434 532 165 1601 SL 08/06 SEMI Blackstone
Amsoil XL-7500 5w20 334 1096 209 3061 SL 06/06 SEMI Staveley
Castrol Act Evo 20w50 765 1126 1724 SG 05/06 DINO Staveley
Castrol GPS 4STK MC2 20w50 767 1133 1544 SG 05/06 SYN Staveley
Castrol GTX 20w50 1157 1422 1848 SM 11/05 DINO Staveley
Castrol GTX High Mile 20w50 1248 1382 1848 SM 06/06 DINO Staveley
Castrol Syntec 5w40 786 918 1979 SL 09/06 SYN Blackstone
Castrol Syntec 5w50 921 914 58 2628 SM 11/05 SYN Staveley
Castrol Syntec Blend 20w50 937 916 1197 SM 03/07 SEMI Staveley
Castrol Tection Extra 15w40 965 1094 46 2461 CI-4 3/07 DINO Blackstone
Castrol TWS 10w60 425 1294 111 2383 SJ 06/06 SYN Staveley
Chevron Delo 400 15w40 1191 1622 3668 CI-4 06/06 DINO Staveley
Delvac 1 5w40 1390 1803 76 2583 CI-4 11/05 SYN Staveley
Delvac 1300 Super 15w40 1380 1702 78 2388 CI-4 11/05 DINO Staveley
Elf 505.01 VW 5w40 584 1092 2691 SL 05/06 SYN Staveley
Exxon Av Break-in oil 20w50 1 4 23 N/A 11/05 DINO Staveley
Exxon Av Oil 20w50 702 32 33 N/A 11/05 SEMI Staveley
Exxon Superflow 20w50 717 848 96 2650 SM 06/06 DINO Staveley
Ford Motorcraft 5w20 545 848 298 2005 SM 01/07 SEMI Staveley
Harley Davidson Syn3 20w50 1081 1182 264 1482 SG 11/05 SYN Staveley
Havoline 20w50 425 494 87 1049 SM 03/07 DINO Blackstone
Joe Gibbs Racing XP5 20w50 920 1231 504 SG 04/07 SEMI Blackstone
Kendal GT (Vintage) 20W50 1229 1415 2408 SE 11/05 DINO Blackstone
Kendall GT 20w50 904 1233 2885 SM 06/06 DINO Staveley
Kendall GT 10w30 582 872 278 1416 SM 11/05 SEMI Staveley
Kendall GT 10w40 598 897 282 1565 SM 11/05 SEMI Staveley
Lucas High Perf. Motor Oil 20w50 386 460 214 1079 SM 02/07 SYN Blackstone
Mobil 1 0w40 761 876 167 2630 SM 03/07 SYN Blackstone
Mobil 1 0w40 796 907 178 2650 SM 03/07 SYN Blackstone
Mobil 1 0w40 808 976 185 3256 SL 04/03 SYN Blackstone
Mobil 1 0w40 706 834 148 2246 SM 02/05 SYN Blackstone
Mobil 1 15w50 952 1030 41 2175 SM 03/07 SYN Staveley
Mobil 1 EP 15w50 1193 1376 228 2970 SL 04/07 SYN Blackstone
Mobil 1 EP 15w50 1062 1279 79 2485 SM 04/07 SYN Blackstone
Mobil 1 EP 15w50 906 1024 72 2071 SM 01/06 SYN Blackstone
Mobil 1 EP 15w50 1315 1428 226 2593 SL 11/05 SYN Staveley
Mobil 1 mx4t 10w40 1277 1460 188 2025 SG 03/07 SYN Blackstone
Mobil 1 mx4t 10w40 1411 1623 188 2248 SG 04/07 SYN Blackstone
Mobil 1 R 0w30 1399 1536 178 3051 SG 02/04 SYN Blackstone
Mobil 1 Super Syn 15w50 1343 1390 205 2601 SL 11/05 SYN Staveley
Mobil 1 Truck & SUV 5w40 1034 1247 51 2826 CI-4 04/07 SYN Blackstone
Mobil 1 V Twin 20w50 1329 1949 204 2130 SG 11/05 SYN Staveley
Mobil 5k Clean 10w40 660 1028 2895 SM 06/06 DINO Staveley
Mobil High Mile 10w40 527 1021 2844 SM 06/06 DINO Staveley
Motul 300V Competition 5w40 1317 1409 19 3273 SH 04/05 SYN Blackstone
Motul 300V Competition 15w50 1139 1130 20 2410 SH 05/05 SYN Blackstone
Motul 505.01 VW 5w40 973 1226 2830 SL 05/06 SYN Staveley
Motul Competition 15w50 1148 1327 11 2723 SH 05/06 SYN Staveley
Motul Tekma Mega 15w40 1220 1737 145 3469 CI-4 05/06 DINO Staveley
Mystik 15w40 1130 1224 3104 CI-4 03/07 DINO Staveley
Mystik 10w50 700 799 2003 CI-4 03/07 SEMI Blackstone
Pennzoil 20w50 501 800 223 2062 SM 01/07 DINO Staveley
Quaker State Q Full Syn 5w50 923 908 1917 SM 11/05 SYN Staveley
Redline 15w50 924 1004 27 2287 SM 02/07 SYN Blackstone
Redline 10w40 1440 1872 3039 SL 11/05 SYN Staveley
Rotella 15w40 843 946 26 1881 CJ-4 03/07 DINO Blackstone
Rotella 15w40 996 1130 32 2054 CJ-4 04/07 DINO Staveley
Rotella 15w40 1278 1555 2946 CI-4 11/05 DINO Staveley
Rotella 5w40 1397 1552 2921 CI-4 11/05 SYN Staveley
Royal Purple 20w50 668 763 2034 SJ 02/07 SYN Blackstone
Royal Purple 20w50 1290 1337 3295 SJ 11/05 SYN Staveley
Royal Purple Max Cycle 10w40 4085 1222 2599 SJ 07/05 SYN Blackstone
Royal Purple Max Cycle 20w50 3179 1030 2142 SJ 04/07 SYN Blackstone
Royal Purple Max Cycle 20w50 3907 1458 2478 SJ 11/05 SYN Staveley
Royal Purple Racing 51 20w50 1285 1417 2639 SJ 11/05 SYN Staveley
Royal Purple XPR 10w40 1034 1741 2709 SJ 12/06 SYN Blackstone
Schaeffer 7000 Supreme 20w50 1249 1626 2451 SL 06/06 SEMI Staveley
Schaeffer 9000 Supreme 5w40 1113 1315 10 3126 SL 07/05 SYN Blackstone
Torco SR-1 20w50 363 412 759 SG 03/07 SYN Blackstone
Torco SR-5 20w50 1072 830 10 1481 SG 02/07 SYN Blackstone
Torco T-4SR 20w50 1059 969 1293 SG 05/06 SYN Staveley
Torco TR-1 20w50 670 571 958 SG 03/07 SYN Blackstone
Torco V Series ST 20w50 1030 1286 2231 SG 05/06 SEMI Staveley
Valvoline All Fleet Plus 15w40 1110 1232 3559 CI-4 10/06 DINO Staveley
Valvoline Durablend 20w50 566 732 13 2606 SM 06/06 SEMI Staveley
Valvoline Max Life 20w50 691 879 17 2170 SM 11/05 DINO Staveley
Valvoline Prem. Blue 15w40 1314 1838 158 4329 CI-4 06/06 DINO Staveley
Valvoline Synpower 20w50 605 689 1786 SM 03/07 SYN Blackstone
Valvoline VR1 20w50 1085 1293 17 2242 SL 11/05 DINO Staveley
Valvoline VR-1 NSL 20w50 835 976 10 819 SL 03/07 DINO Blackstone
Valvoline VR-1 NSL 20w50 842 962 11 838 SL 03/07 SYN Blackstone
Bardahl No Leak/Smoke 53 4 0 11/05 O/A Staveley
Boron Motor Silk 116 0 05/06 O/A Staveley
CD-2 Maxx Detergent 1 7 2416 11/05 O/A Staveley
CMW Racing Concentrate 2292 1147 358 06/06 O/A Staveley
GM Cam Lifter Prelube 5710 5876 29004 01/07 O/A Blackstone
GM EOS Assembly Lube 5762 6221 8265 01/07 O/A Blackstone
Lucas Oil Stabilizer 36 13 0 01/07 O/A Staveley
Power Service Oil Extender 3567 4945 6394 11/05 O/A Staveley
Schaeffer Micron Moly 110 5 0 08/06 O/A Staveley
STP Blue 1704 2436 88 11/05 O/A Staveley
STP Red 2115 3932 901 11/05 O/A Staveley
Valvoline Max Life Protect 537 768 22 3871 11/05 O/A Staveley
Valvoline Synpower 356 551 650 11/05 O/A Staveley
Here are the running averages for all the oils tested thusfar:
API P (ppm) Zn (ppm) B (ppm) Mo (ppm) Ca (ppm) Mg (ppm) Na (ppm) Total Detergents
SE-SJ 1301 1280 151 357 1936 293 214 2443
CI-4 1150 1374 83 80 2642 199 2840
SL 994 1182 133 273 2347 109 22 2479
CJ-4 819 1014 26 2075 7 2082
SM 770 939 127 122 2135 13 139 2287
Link to the entire post is here:
http://board.moparts.org/ubbthreads/sho ... er=3740790
-Andy
'97 XJ 4.6L Stroker
'00 Explorer
'67 Mustang Fastback (project)
That mobil 1 hi-mi is a lil low on the P side, but good on the Z side.
gradon wrote:That mobil 1 hi-mi is a lil low on the P side, but good on the Z side.
I love the Mobil 1 Extended Performance 15w50:
viewtopic.php?p=746#p746
seanyb505
Stroker Displacement: 280ci
Post by seanyb505 »
That is an awesome wealth of information! I noticed that some of the dates are from two years ago, and that newer versions have less of these elements.
97 XJ 4.6
90 MJ 4.0 - sold
Flash
Post by Flash »
John wrote:SAE specs 1200 ppm for zddp and the European societies specified even higher levels. Lets see....... "Even prior to the introduction of the API's SM standard, there was concern that current API SL standards from back in 2003 may inhibit the backwards compatibility of motor oils, specifically referring to the limitation of ZDDP, which is "the most effective combined anti-wear and anti-oxidant additives currently available." SAE 2003-01-1957, Effect of Oil Drain Interval on Crankcase Lubricant Quality, Shell Global Solutions. The authors continue to state that oils are required to provide longer protection in severe operation but that an oils performance is "limited by environmental considerations." Furthermore, they state that it is hard to predict the effects of these reformulated oils in just a single oil change and may only be evident over an engine's lifetime".
There ya go, I knew you had more then just a song and a prayer in yeah!!!! :P
Flash
Flash
Post by Flash »
seanyb505 wrote:That is an awesome wealth of information! I noticed that some of the dates are from two years ago, and that newer versions have less of these elements.
Ya Glad you made that comment.............When back and check my Favorite Summer oil. And found out that the Castrol GTX 20/50 hasn't been retested since 11/05 :o
flash
Post by John »
The oil additive packages are being reformulated constantly. Unless analysis data is very new, suspect it to be lower. My last oil change put motorcycle oil in my crankcase.
oletshot
Post by oletshot »
My problem with the oils that have acceptable levels of Zn & P is they are as thick as molasses. Rotella syn 5w-40 is the best I can find. I would like the Mobil 1 R 0w-30 but thats SG rated and from 2004, I have a better chance finding a unicorn. :lol:
'98 XJ 2-door, '94 YJ.
seanyb505
Post by seanyb505 »
I did see some rotella 15w-40, but I dont think it was CI rated.
97 XJ 4.6
90 MJ 4.0 - sold
4point6
Post by 4point6 »
I got the last gallon of Delo 400 today at the local Walmart for break in oil (along with some EOS). Anyway, it looked like they were starting to stock Delo400LE (low emissions) instead of the regular stuff. The LE is CJ, not CI rated. Plus my gallon was all dusty like it was sitting around for a while. Hopefully the regular is still available.
Also they had ACCEL 10w40, rated SE, labeled "for vehicles 1988 and earlier" Any one heard of this stuff? Maybe its formulated with the needed zinc in it. They also had ACCEL SAE 30, SA (!) rated, for "vehicles 1930 and earlier" I think that is straight dino oil, nothing added. I think had read somewhere that 88 is when they started reducing the ZDDP.
They also had Rotella 5w40, CI rated, synthetic (I think) and 15w40, CJ rated
-Andy
'97 XJ 4.6L Stroker
'00 Explorer
4point6
Post by 4point6 »
OK so I did some poking around, found this at BITOG, for the LE:
http://www.bobistheoilguy.com/forums/ub ... ost1157741
and also this for Mobil 1 15W50 EP:
http://www.bobistheoilguy.com/forums/ub ... ost1157578
-Andy
'97 XJ 4.6L Stroker
'00 Explorer
Mgardiner1
Stroker Displacement: 284 CI
Post by Mgardiner1 »
I know this thread has been dead for awhile, but it was a highly discussed topic. I work for a John Deere dealership. John Deere believes very highly in their diesel engine oil called 15w40 PLUS 50. The 50 stands for 50% longer service intervals.
Anyway, its what i've been running in my renix injected stock engine for awhile now, and i was curious if it would be ok for my stroker when its built. I sent in a virgin sample for analysis and came back with 1250 ppm zinc, which seems to be pretty good. Not to mention, i get the oil at cost, and we buy in bulk for extra discounts. Here is the sheet
