Project TJ Claretta
Andre_ITALY
Learning to use the board
Vehicle Model: TJ 4.0
Project TJ Claretta
Post by Andre_ITALY »
This thead start here:
https://www.jeepstrokers.com/forum/vie ... 15&t=6034
I'm planing a stroker built fot my TJ
I've a TJ 1997 4.0, AX-15 manual tansmission, F/R LP9" currie ( 4.86 R&P), 2" lift, 35x12.50r15 BFG m/t (next tire will be 37x12.50r17 BFG m/t). Her name is Claretta :)
As I have already written, I would like a DD jeep, for the holidays (highways use, 80 mph) and weekend offroad.
Currently Claretta does it well :banana: , but a i think with a balanced stroker project do it better :mrgreen:
I've been a second 4.0 engine, for a long term stroker project. it's out of 1997 tj
I can reuse this stuff mounted on Claretta (if not, i sell it and i brought new parts):
- BBK 62mm TB & Spacer
- 505 performance SS fully ported header
- Magnaflow catalytic converter,
- Borla 2.5" catback
- BMC CDA airfilfer cold air intake (w/safari snorkel)
I'm looking for a good project buit, not an extreme project, not a "junky" project. :D
A good compromise $$$/performance :)
if a work is to be done, I do it.
If something is to be bought, I buy it.
This isn't a "no limit budget project", this is a best $$/performance ratio project :D
Mpg like now, or higher if is possibile (standard unlead fuel cost = 7,0 $/gal &up :frustrated: )
Cheromaniac write on original topic (thanks for all you reply!) :cheers:
4.6L Modified "poor man's" stroker
Jeep 4.2L 3.895" stroke crank
Jeep 4.0L 6.125" rods
9.25:1 CR
Stock 4.0 camshaft
0.043" quench height
Bosch 0280155703 injectors for '96-'04 engines
245hp @ 4700rpm, 315lbft @ 3000rpm ('96-'04 camshaft)
or
4.6L low-buck stroker
Custom forged +0.030" bore pistons, compression height 1.380", dish volume 18cc
9.6:1 CR
268hp @ 4900rpm, 326lbft @ 3500rpm
The differences betwen are:
-Pistons
-Performance/custom camshaft
-Injectors
-Head work & big valve
= +23HP, + 11lbft. But at higher rpm
I think these changes increase the budget, but how much? Are they really well spent or waste of money? And the higher rpm make Claretta better onroad and worse offroad?
Here
i've seen the Hesco result:
269hp @4800rpm and 339lbft @3200rpm
About the same power of "4.6L low-buck stroker" but more torque at lower rpm. I think this is better for all use, or not?
Where is the difference on HESCO setup to archive this result? (Hesco calim stock head :shock: ) :huh:
And this stuff make real difference for my project?
- 4CW-6CW-12CW crankshaft
- 99&UP intake manifold
- 65-68-70mm TB
- New valve springs
- Adjustable roller rockers
- Hi volume oil pump
- Hiflow water pump & thermostat housing
- Multi hole injector
-Custom PCM programming
Andre_ITALY
Re: Project TJ Claretta
This post has been read 61 times.
Nobody answered. :huh:
It is probably badly written. :brickwall:
Sorry for my bad english. :worship:
SkylinesSuck
Post by SkylinesSuck »
I wasn't sure the exact question you were asking. What is the budget for your build? Welcome anyways she your English is a lot better than my Italian!
Andre_ITALY
Thank you for your reply SkylinesSuck . :cheers:
I try to summarize.
Budget and Target:
Andre_ITALY wrote: February 22nd, 2019, 7:38 am I'm looking for a good project buit, not an extreme project, not a "junky" project. :D
I do not want to waste money, but I do not want to make stupid savings on spare parts and mechanical jobs
QUESTION A: :huh:
9.25:1 CR
Stock 4.0 camshaft
or
9.6:1 CR
-Pistons
-Injectors
QUESTION B: :huh:
Andre_ITALY wrote: February 22nd, 2019, 7:38 am Here
QUESTION C: :huh:
Andre_ITALY wrote: February 22nd, 2019, 7:38 am And this stuff make real difference for my project?
- 65-68-70mm TB
- New valve springs
SkylinesSuck
I think you would be wasting your time putting a stock cam back in it. The DIY vs. Russ ported head is your call. Obviously the price difference will be large, especially considering where it needs to get shipped to. If daily driving is your main concern, If save my pennies and just DIY clean up your head and if you are feeling brave, port and polish it yourself. I would, however, spend the extra money and go with Russ's recommended pistons. He can spec them to whatever would work best with your setup. The pistons AND the cam I would look to Russ for recommendations and to purchase from him.
And reference the last list of things you were wondering if it would be worth it, other than custom PCM tuning, I'd say no for just something you want better power/driveability out of.
Users browsing this forum: No registered users and 11 guests
