Welcome to www.JeepStrokers.com!!
Not yet a registered user? You are required to Register before you can post within this topic.
Gradon's Stroker Project
Re: Gradon's Stroker Project
Post by gradon » August 1st, 2016, 8:51 am
In the front, I have 2.5" shorter, supposedly 25% stiffer springs from Springworks. Tubular straight adjustable control arms and a custom straight adjustable trackbar from Ironman4x4fab. Addco front 1.125" swaybar. Offset upper balljoints set to max camber. In the rear I have some custom composite mono-leafs from Flex-Form with a 6" arch height rated at 320#/in(double stock rate) and pinned for SUA. For shocks, I've converted the shortest Bilstein 5125&5150s with the t-bars. The rear 8.25" axle is from a 1987 Dodge Dakota, so had the SUA perches the same width as the XJ, the same 5x4.5" bolt pattern, and I was able to re-use the 27-spline Auburn LSD. The shock mounts had to be cut off and re-welded XJ style. The rear also has adjustable hangers. The ride is harsh and I hit bump stops regularly. I want to get the rear up and the nose down(have to section the front axle), get 300-400#/in springs up front, and then source adjustable shocks. It's never finished . . .
Post by gradon » May 23rd, 2019, 7:43 am
Long time! So I’ve still been DDing my 96 and I auto-xed it at Summit Point a few weekends ago. After one run, I had lifter tick at idle and had to rev up to 3k to get the air out and oil in. I ended up 23rd out of 78: http://live.axti.me/results/4JBC8nZ38 (discard the NC/non-comp runs which were runs 6-10 for people that did both sessions). A week later there was lifter tick all day, then later that night the tick stopped and the jeep was down a cylinder. I did a comp check and cylinder 1 was down to 130psi, but the other 5 were 180psi +/-5psi. I removed the valve cover to find that intake rocker #1 was loose. I removed it and found a collapsed lifter. I don’t know if the cam lobe is damaged, but will find out next week.
Post by gradon » May 23rd, 2019, 7:46 am
Pics
SkylinesSuck
Post by SkylinesSuck » May 23rd, 2019, 8:18 am
Pretty cool that you ran there! Sorry to hear about the cam/lifter issue. I feel your pain. Been there myself 4-5 times :-/
Post by gradon » May 23rd, 2019, 8:26 am
SkylinesSuck
Post by SkylinesSuck » May 23rd, 2019, 6:04 pm
Even with a collapsed lifter/wiped lobe, should there be any play with the rocker arm?
Post by gradon » May 23rd, 2019, 8:24 pm
The lifter no longer has springiness so can’t maintain oil pressure to stay lifted. I’ve never experienced a collapsed lifter, so will see. The rocker looked fine and the push rod wasn’t bent and still had oil in it and fed the top of the rocker.
Post by gradon » July 18th, 2019, 2:00 pm
Carnage:
SkylinesSuck
Post by SkylinesSuck » July 18th, 2019, 6:46 pm
Sorry man. Been there, done that. Too many times. Plans?
Post by gradon » July 18th, 2019, 6:56 pm
I left a message with Russ today. I definitely need a cam, lifters, cam bearings, a crank sprocket key, and maybe the rocker and pushrod for #1 intake. Over the ten years I’ve thrashed it, I’ve had a stock timing set fail that sent metal everywhere and a crank snout snap(so another crank and crank bearings). The mopar 30ab cam was 256* 108lsa and .45” lift. I want to go a tad bigger.
SkylinesSuck
Post by SkylinesSuck » July 19th, 2019, 1:15 am
So that was one of the vaunted "wide lobe" cams?
Post by gradon » July 19th, 2019, 11:28 am
Yes it was. I think it was not the cam’s fault though, but the cam bearings wearing. The 2nd bearing in right by #1 intake was the worst.
SkylinesSuck
Post by SkylinesSuck » July 19th, 2019, 12:48 pm
Oh, so the lobes aren't worn? I don't recall, were you having oil pressure issues?
Post by gradon » July 19th, 2019, 2:52 pm
Just the #1 intake lobe is worn and has a snag on the edge. Oil pressure was down to 10psi hot, but had [email protected] I just ordered the comp cam 68-235-4, so will be bumping up the lift.
Tolemar
Post by Tolemar » April 13th, 2020, 1:23 pm
Any updates ? Sorry to bring back an old thread but I just read the whole thing and like to know the outcome . How do you like that cam?
