Stroker in a Rebel...
- Vehicle Year: 1968
- Vehicle Make: AMC
- Vehicle Model: Rebel
Toying with the idea of replacing the 232 in my 68 Rebel with stroked 4.0. I know V8 is an option (if I could find a donor car) but I kinda like the idea of keeping it a 6 cyl. Has any one built one for use in a street car? Id like just a simple motor... no EFI, no power streeting, and a delco alt to replace the Motorola unit.. Id like 10:1 comp, big vaves, lumpy cam, and a 4bbl carb. Has anyone built one?
Re: Stroker in a Rebel...
Why?oxide80 wrote: big vaves,
- Vehicle Make: AMC
well a couple of the heads I was looking at were ported and polished and ran 1.94 to 2.02 GM valves. I know its prob overkill for a street motor, but I want more higher reving and less lower end. In the past I always used modded 1.94's and 2.02 haeds when building SBC. The only 6 Cyls I have built were bone stock, one 258, a 300 Ford, and a few GM 250's. So anyhting performnce for a 6 is ne w to me.
I have seen no proof that the larger valves provide any benefit due to shrouding, just adding weight to the valve train. As for a large lumpy cam, I would also advise against that. These engine don't like to rev as would an engine with a larger cam. A stroker would be fun in s alight street car.
- IH 392
I say go for the V8!, I swapped the 232 in my American for a 258 then a 4bbl 343! and then a 360!
The stroker should bolt right in?, you may find the oil pan hangs down farther than with the 232?, IIRC?, the 258 hang down more than the 232 did??
If you go V8 you'll need to change the cross member too!, there are two sizes for the AMC's, big & small, I know this first hand!, I had the V8 cross member from the donor Javelin all painted and ready to install and it was 2" to wide!, I had to get one out of a Hornet!
Users browsing this forum: No registered users and 16 guests
