XJ and Liberty NP242 Compatibility
TJryder
Vehicle Model: TJ
Post by TJryder »
Hi, I just learned rhat not only XJ was fitted with NP242, same transfer case was also later used in Jeep Liberty.
Are the two transfer cases same or do they have different spline / bolt pattern?
°O|||||||O°
whaleinafishbowl
Vehicle Model: ZJ
Re: XJ and Liberty NP242 Compatibility
Post by whaleinafishbowl »
I'm sure you've already found this out, but for anyone else who finds this in the future - a Liberty 242 will not work in an XJ or ZJ since the liberty 242 has no speed sensor / gear in the tail-housing. The PCM uses that speed sensor for the speedo gauge and transmission shifting among other things.
OME HD Coils / 3/4" Spacers
Bilstein 5100s
IRO Adj. control Arms / Track Bars
Addco Sway Bars Front and Rear / JKS Quick Disconnects
2x6 Tube Rock Sliders / IRO Frame Stiffeners
Ford 8.8 / HPD30 4.56 Gears
'18 JK Rubicon Recons / 32" BFG M/T KMs
Users browsing this forum: No registered users and 15 guests
