coil rail eliminator problems
Hi just started the preliminaries for my coil rail eliminator on my 01 with a 98 block and head stroker. I just finished the 3 foot extender harness and it still runs on the rail so that's good. my problem is that the connector on my 01 into the rail does not directly connect into the AIRTEX 5C1432 replacement coil pack. when staring at the airtex unit with lock clip up...there is a thin raised square rail on the upper left side that has no corresponding cutout on the 01 connector. I can easily grind away but I thought this was a direct fit connection and I want to make sure I have it right before I start cutting away stuff...thanks..Will try to get pictures later today
Re: coil rail eliminator problems
These show the difference between my stock coil rail plug and the airtex plug...the airtex has the square rail on top left that blocks my connector from sliding on. I can easily grind it down but I didn't think you had to based on what I read . I want to make sure that's the only issue before I cut the plug...thanksdownload/file.php?mode=view&id=2340http ... ew&id=2339
Users browsing this forum: Bing [Bot] and 11 guests
