Cam Choice ? I figured I should ask the experts
blu3fan
Vehicle Make: cherokee
Vehicle Model: jeep
Post by blu3fan »
Hello again.
Long time. Older. Wiser. But still need some opinions.
my 4.6 stroker has a valve tick. its time to ditch this comp cams Cam
Im running yella terra 1.7
and currently K68-231-4 is the cam.
http://www.summitracing.com/parts/CCA-K68-231-4/
springs and retainers
Mopar Performance spings P5249464 with Mopar Performance retainers P4452032
stock pushrods.
arp head bolts.
anyone got an opinion on whats the best options ?
I have a new set of stock valve springs if needed.
Re: Cam Choice ? I figured I should ask the experts
Why do you think it's time to ditch the cam? Does it have any lobe wear? You could just replace the lifters if that's the only problem.
2006 Mustang GT - 5MT - Modded Midlife Crisis Car :mrgreen:
blu3fan
Vehicle Model: jeep
Post by blu3fan »
Honestly the cam is noisy.
I think I have a bad lifter or bent pushrod.. so its like a *while I am in there type of thing.
also. I do not like the profile. it has too much top end and not enough bottom end.
Strong Poster
Strong Poster
Post by Russ Pottenger »
A better choice with your 1.7:1 rocker ratio would have been the slightly less aggressive 68-232-4 with 113° LSA rather than the 111°
Upgrading from the 822 lifter to the 867 that has closer tolerances also seems to help.
Feel free to shoot me an email if you have any further questions. I'd even be willing to shoot you some better pricing to try and get you to better "Comp Cam Karma"
blu3fan
Vehicle Model: jeep
Post by blu3fan »
Thanks Russ. ill look into that. and contact you when I am ready to do this
Btw. That awesome timing set is still flawless.
Users browsing this forum: Google [Bot] and 28 guests
