Welcome to www.JeepStrokers.com!!
Not yet a registered user? You are required to Register before you can post within this topic.
What is cause behind a 258 sounding a little like a diesel?
CJ-8_Jim
Post by CJ-8_Jim » June 8th, 2017, 7:11 pm
My 258 overheated due to a cooling problem. Now it sounds like a diesel at idle with the hood up, but you can't really hear it with the hood closed.
What is the likely problem?
Stroker: 4.59L, SCR 9.47, Hesco 1995 MPI with adjustable FPR, TJ intake connected to grill, aftermarket OEM-size exhaust.
CJ-8: mostly stock, but becoming less so.
D44 rear, 2.73 gears on 31", T-176
Re: What is cause behind a 258 sounding a little like a diesel?
Post by IH 392 » June 8th, 2017, 7:53 pm
They are subject to excessive rocker arm bridge wear and lifter noise, that's probably what you're hearing?
SkylinesSuck
Post by SkylinesSuck » June 9th, 2017, 4:58 am
Something warped from the heat possibly causing a broken piston/skirt? Anything like that making noise is going to require the motor coming apart.
