Quick question regarding erasing existing ECU memory to allow a new “Adaptive Memory” to be developed. I've made quite a few changes lately and the stroker is running like crap as it always does when power is disconnected from the ECU until driving 200-300 miles or so while it re-learns" it's new settings. My question is I know the below procedure works fine on ODBII systems, but will it also work on 91-95 OBDI systems as well?
Disconnect the POSITIVE battery Terminal and touch it to ground ( not the battery negative terminal ) for 30 seconds. The engine block or the A/C compressor pump will work as a ground. (This is to discharge the PCM capacitors, which maintain the Adaptive Memory.
Reconnect the Battery Cable
Turn Ignition Switch to the “On” position but DO NOT start the engine
Turn Headlight “On”
Turn Headlights “Off”
Turn Ignition Key “Off”
PCM (ECU) Fast Learn Mode
- Comanche91
- Vehicle Year: 1991
- Vehicle Make: JeeP
- Vehicle Model: Comanche
Re: PCM (ECU) Fast Learn Mode
Touching the positive to ground will suffice to drain the capacitors. I've seen that headlight method before and I don't understand the reasoning behind the headlights on the XJ(or MJ in your case). They aren't linked to the PCM nor is there a BCM linked to the PCM.
- Comanche91
Maybe this applies to just TJs and YJs. I'll try this tomorrow and see what, if anything, happens. I've just started the "re-learning" process after removing the Unichip and rewiring the ECU harness last week.Turning the headlights on then off; after erasing volatile memory, the computer senses this as a trigger to return PCM nonvolatile memory to default, or factory new, in quick learn mode.
Thus, with volatile memory gone due to no power and nonvolatile memory reset to default, the computer is blank as far as stored adaptive memory. Clean and new and ready to record.
Users browsing this forum: No registered users and 34 guests
