Page 11 of 13
Re: Calculator...
Posted: April 21st, 2009, 6:36 pm
by Exos
While you're at it, why not add the Crower cams too?
Re: Calculator...
Posted: May 8th, 2009, 7:35 pm
by laxplayermjd
anybody else want these cams added too? im gettin my block back tomorrow gonna be getting ready to play with the calculator a bunch. Leaning towards mopar cam because i can get a sweet deal but also want to calculate with lunati also.
Re: Calculator...
Posted: May 12th, 2009, 2:42 pm
by Muad'Dib
SilverXJ wrote:Some Other cams you can add to the calc if you want:
Comp Cams: (all 4* advance built in)
part; duration; lsa
68-115-4; 240; 108
68-200-4; 252; 110
68-201-4; 260; 110
68-232-4; 250; 113
68-239-4; 262; 111
Isky: (all 0* advance built in)
part; duration; lsa
1331M; 248; 108
133126; 262; 108
133127; 270; 109
133128; 280; 109
Lunati (all 4* advance built in)
part; duration; lsa
63500; 250; 112
63501; 256; 112
63502; 262; 112
63503; 268; 110
Someone in another thread mentioned that the comp cam info given here is incorrect. Can someone please check on these and give me the correct information? Thanks!
Also, if you guys want other cams added you will need to post the information on that cam in this thread, just as silverxj did in the quoted post above. Manufacturer, Model, Duration, LSA, Advance/Retard. Thanks very much!
Re: Calculator...
Posted: May 12th, 2009, 4:12 pm
by laxplayermjd
Mopar
Part, Duration, lsa, Advance/retard
P4529228AB , 240*, 108*, 0 Advance/retard
Also as stated in another post Comp Cam data incorrect
From angelfire
68-232-4 , 250*, 107*, therefore 4* Advance
Comp Cams datasheet shows
Source
http://www.compcams.com/Cam_Specs/
Some one else can verify, possible ive made a mistake
68-115-4, 240*, 108*,
0 Advance/retard
68-232-4, 250*, 110*,
3* Advanced
Re: Calculator...
Posted: May 12th, 2009, 4:17 pm
laxplayermjd wrote:Mopar
From angelfire
Source
0 Advance/retard
3* Advanced
The 4* I got was from asking cam if all their 4.2L cams had 4* advance... I must had a lazy tech, and they said yes.
Looking at my grind card from my old 68-232-4 the specs are 250*, 113* LSA, and 3* advance. 110* is the intake center line.
Re: Calculator...
Posted: May 12th, 2009, 4:28 pm
by Muad'Dib
so... what do i put in there
Re: Calculator...
Posted: May 12th, 2009, 4:32 pm
by laxplayermjd
68-232-4, 250*, 113*, 3* Advanced
I had the lsa and intake centerline backwards, my mistake
Silverxj, verify this?
Re: Calculator...
Posted: May 12th, 2009, 6:00 pm
I concur
Re: Calculator...
Posted: May 14th, 2009, 1:08 pm
by Muad'Dib
I fixed the comp cam, and added the mopar cam that was provided.
Re: Calculator...
Posted: August 3rd, 2009, 3:48 pm
by Muad'Dib
Is this still working out good for everyone?
Re: Calculator...
Posted: August 8th, 2009, 7:17 am
by laxplayermjd
yes, great for me
Re: Calculator...
Posted: August 29th, 2009, 6:16 pm
by Exos
How come the OEM cam info is missing years 91-98 ? Is there a difference between a 98 HO cam and a '99 ? And how come the LSA and duration are different from Dino's page?
Re: Calculator...
Posted: August 30th, 2009, 10:23 am
by Muad'Dib
I think the difference is because we are using seat to seat values, and he is using @.050.
I could be wrong though, as i have just gone off of what people have given me in this thread. If they need to be changed, or if cams need to be added please give me the proper information.
Re: Calculator...
Posted: August 30th, 2009, 10:32 am
by Exos
He's not using 0.050 alone, he states advertised as well. My question is why is it different from our calculator?
I need this info badly, as I am there : cam choice. I'll be buying in the next few weeks.
Years missing, and strange numbers for the stock HO cam..... could someone verify this please? My only reference is Dino's page. If it's right, and I'm pretty sure it is, then some data in the calculator are wrong.
Re: Calculator...
Posted: August 30th, 2009, 12:13 pm
by Bodo
According to my literature, 87-95 used the same melling camshaft: MC809
96-98 XJ/ZJ & 97-99 TJ: MC1376
99-04 XJ/WJ & 00-06 Wrangler: MC1377
You can get specs from:
http://www.mellingengine.com/Portals/5/ ... ations.pdf
