400 ft/lbs of torque on 87 octane?
- Garmobozia1260
- Stroker Displacement: 4.0
- Vehicle Year: 2002
- Vehicle Model: WJ
400 ft/lbs of torque on 87 octane? My brother was going to go LS1 swap in his 04TJ , but now really liking the idea of a stroker instead, his question is 400 ft/lbs of torque on 87 octane possible ?
Re: 400 ft/lbs of torque on 87 octane?
That's a tough number to hit with high compression and 93 octane. Possible maybe with nitrous.
Not happening. A N/A stroker that can run 87 octane fuel might reach ~320lbft at best. To reach 400lbft you'd need a power adder, and only a complete fool would run 87 octane fuel with a power adder.
LS Family = Gen. 3, 5.7L, Aluminum Block, Car Engines
Performance Specifications
Compression Ratio 10.2:1
Horsepower Rating 305-350 hp
Torque Rating 335-365 ft./lbs
Ls1’s don’t make 400ft#s either. But a stroker with 2 less cylinders can be built close to those numbers above. Granted the later gen ls versions made more power.
I get this question asked a lot.
If you’re building an off-road buggy of sorts from scratch, a LS should giviin a strong consideration for many factors. Decent reliable power, more compact meaning lower hood line, .. But if you already have a 6cy Jeep platform already there, a 4.6/4.7 stroker with a good cylinder head and Intake/exhaust, You’ll be so close to the LS numbers that to me it doesn’t make sense in both finances and labor to do the swap over for most people.
My .02
My .02
Users browsing this forum: Google [Bot] and 22 guests
