Page 10 of 10
Posted: June 3rd, 2019, 1:35 am
by Cheromaniac
Russ Pottenger wrote: ↑June 2nd, 2019, 1:26 pmI believe that is what Josh is running and it’ll up his static compression ratio calculations more in line what he’s looking for
Yup. I make it 9.50:1.
Posted: June 3rd, 2019, 8:32 pm
by jpradcliffe
Not Silvolite. 677AP +.030. 15cc dish. Hadn't know those had a larger dish when I ordered them. Oh well. I'm thinking that the low 9 compression is ok considering could always play with a small amount of boost, provided I don't float a valve lol.
Posted: June 11th, 2019, 10:09 pm
by jpradcliffe
Posted: June 12th, 2019, 1:08 am
by Cheromaniac
jpradcliffe wrote: ↑June 3rd, 2019, 8:32 pm
It'll be fine.
Posted: September 15th, 2019, 4:44 pm
by jpradcliffe
Ok so. Big thanks to Russ for the roller rockers!
Now: Lifters, gasket, head, pushrods & rockers installed.
Oil pump primed.
I go to hand crank the motor to check rockers and pushrod lengths andddddd....... Da dah. Motor will not make a full turn.
I Drain the oil. Pull the pan. And....Guess what?
Ye ol' machine shop had "neglected" to shim/washer the main girdle.
Rods would have hit the girdle and the Motor would have been destroyed on first crank.
I am sure there is wisdom on this subject and would greatly appreciate any advice.
This video
https://youtu.be/wH3MkRHSyw0 says to add washers on rod stud and under main....I am not sure that is wise. Please advise.
Posted: September 15th, 2019, 4:46 pm
by jpradcliffe
Oil pump primed.
I am sure there is wisdom on this subject and I would greatly appreciate any advice.
This video
Posted: September 16th, 2019, 3:43 am
by Cheromaniac
Here's your answer:
The rod caps wouldn't clear the main bearing stud girdle, so two 5/16" hardened steel washers had to be inserted on each stud to raise the girdle and provide the necessary clearance.
Posted: September 17th, 2019, 8:45 pm
by jpradcliffe
Ah. Why thank you.
So I just decided to clearance the girdle at the contact point. Fits and rotates perfectly and the pan fits without the need for further modification.
So that's good.
Anywho. I have another query.
So being that my
Dynamic compression is 8.54 and my
Static compression is 9.15,
Were I to run a small turbo and intercooler setup at say 6 to 8 #'s of boost, what injector would I need? (I've read that folks are running 36#) but at what psi?
I'm currently at 39# ....provided I size the injectors properly, can I get away with running this setup with just a boost referencing fuel pressure regulator and check valve on map until I can understand/afford a mega squirt?
Please advise and thanks in advance.
Posted: November 11th, 2020, 7:00 am
by 4.2stroker
I have a 4.2 stroker engine
2000 xj block
Bored .60 over
New silvolite UEM-2229 pistons installed on the 4.0 rods
AMC 232 crank ground and polished .10/.10 and the snout shortened to use the serpentine crank pulley
0630 head resurfaced
New valves springs retainers and keepers
Mild cam from comp cams
New oil pump and pick up tube
What fuel injectors would you recommend for my 2000 xj?
What other parts would you recommend that I change?
The xj that the motor is going in is completely stock
Posted: November 11th, 2020, 10:04 pm
by Cheromaniac
The Bosch 0280155703 injectors should do the job. To help your 4.2 stroker breathe, I suggest you add a 62mm TB, header, and 2.5" exhaust.
Posted: November 12th, 2020, 3:24 am
by 4.2stroker
Cheromaniac wrote: ↑November 11th, 2020, 10:04 pm
Thank you I appreciate your help
Posted: June 17th, 2021, 1:10 am
by Jed
So I think I had a mini stroker I got out of trade. I had to replace valve cover and oil pan. Someone dropped it off a fork lift. It also sat on it side for 3 + months after being jumped through a barn. It ran great for A few years. Then I thinking it broke from camshaft thrust and would eat the gears off my distributor.
I say it’s a mini because of the Size of the lobes on the cam. I was trying to figure out what can I should buy to replace the one I had. I saw the lobe size was smaller than a stock 4.0. So I ask about it on the forum and someone pointed out that my cam was from a 4.2 due to the size.
So I replace it with a cam from cleggS stage one cam and did throttle body lifters and rods. It runs hot now but sounds good but did I make the right choice in cams? Is the cam the reason it runs hot now or what’s the deal can you help me thanks
Posted: June 18th, 2021, 10:08 pm
by Russ Pottenger
Jed,
To help advise you in selecting a Camshaft is your block a 1999 and later block utilizing thrust plate style cam and are you planning on retaining your stock valve springs?
