Cylinder spacing on 4.0 block
Posted: March 11th, 2009, 11:20 am
by Plechtan
Maybe this should be move to FAQ section
Cylinder spacing on a 4.0 Block is 4.380" center to center. Lifter bore spacing is 2.02 center to center .903 lifter, Center pushrod, oil through pushrod.
Re: Cylinder spacing on 4.0 block
Posted: March 11th, 2009, 11:36 am
by yuppiexj
Isn't that the same bore spacing as a SB Ford?
runs to drop a pair of Dart Windsor heads on the band saw to create the awesomest 4.0 crossflow head.
Posted: March 11th, 2009, 1:06 pm
by Muad'Dib
I added your post to the FAQ's Thanks!
Posted: March 13th, 2009, 3:54 pm
by Alex22
Head bolts don't line up.
Posted: May 4th, 2009, 10:27 am
by Plechtan
Maybe you could buy the heads directly from Dart and ask them not to drill the head bolt holes. A welder does wonders with an aluminum head.
I wonder if they kept the same spacing with the OHC motors?
Posted: May 4th, 2009, 12:09 pm
by lafrad
ooo... OHC would be interesting... probably start running into limits on the strength of the block and parts there....
Posted: May 4th, 2009, 8:32 pm
by Plechtan
The Ford modular engines use a 100mm cylinder spacing, that is less than 4 inches. I wonder what the spacing is on the Chevy (4.3?) inline 6 they use in the trailblazers, that is an OHC motor.
