I have found a boat of info on here and thank you guys for being a well of information. I have looked but can't seem to find a definite answer on this subject matter.
I'm putting a 7120 head on my 258 short block with a mild street cam from Russ. I am aware the 258 intake manifold needs a dowel shaved off to mate up to the 7120 head, but my question is should I go with an Offenhauser intake manifold and 4-barrel carb or can I stick with my current intake manifold and use a 2-barrel carb? if so, what carb is recommended?
Thanks again.
4.0 head on 4.2 short block intake and carb options
- Stroker Displacement: 4.2
- Vehicle Year: 1989
- amcinstaller
- Vehicle Year: 1980
- Vehicle Make: AMC
- Vehicle Model: Spirit
Re: 4.0 head on 4.2 short block intake and carb options
Does the cam from Russ have the fuel pump lobe? Just curious not trying to be rude
1980 AMC Spirit Restomod in Progress
No worries,amcinstaller wrote: ↑October 25th, 2023, 11:14 am Does the cam from Russ have the fuel pump lobe? Just curious not trying to be rude
the details of which cam have not been fully ironed out, but I would like on with a fuel pump lobe to retain the mechanical fuel pump. worst comes to worst ill get an electric fuel pump and a fuel pressure regulator hooked to a carb
