Transmission Cooler and Fluid Info
‘01SilverXJ
Vehicle Year: 2001
Post by ‘01SilverXJ »
What is a good transmission cooler for my 4.6L stroker? I also need advice on fluid. I was changing the filter and the previous owner was running a certain fluid with a horrendous smell like cat urine. Does anyone know what fluid this is and should I flush it or replace it with the same fluid? Thanks
Tolemar
Re: Transmission Cooler and Fluid Info
Post by Tolemar »
Biggest cooler you can fit! I have a 26kgvw cooler and run standard dextron3. my trans never sees 200 even on an 100+degree day. btw I don't use the cooler in the radiator either.
jeeppoor
Where's the "any" key?
Vehicle Year: 1976
Vehicle Make: Juggy
Vehicle Model: Home made
Post by jeeppoor »
Tolemar wrote: May 18th, 2020, 4:04 pm Biggest cooler you can fit! I have a 26kgvw cooler and run standard dextron3. my trans never sees 200 even on an 100+degree day. btw I don't use the cooler in the radiator either.
What cooler do you run?
Make and model please.
