Grouting a Block
Posted: January 26th, 2014, 7:55 pm
"Grouting is a means of increasing crankcase and liner stability, which is beneficial as all engines distort under load, and distortion contributes to piston ring blowzy. Doing an average of 40-45% of it's capacity w/ a hard-setting epoxy." Seeing how most of the combustion is happening up top and grouting the lower end might help to keep things true.
Above in quotes from " Secrets of Speed"
isbn 978-1-845842-97-0
I'm respectfully asking for feedback from those that have had 1st or 2nd hand experience with this. Please share links to sites if you haven't had either and found some information that might pertain to it from someone who has.
Thank you,
Brian
Thank you,
Brian
