ecu question
- Vehicle Year: 1969
- Vehicle Model: commando
ecu question
can anyone help me with my problem, that i might be having or i think im going to have. i have a 95 4.0 with with 4cw 4.2 blah blah, any way i have a big big cam, .493 intake and .512 exhaust. will i need to have the ecu reflashed in order for the jeep to run, or will the adjustable map sensor, do all the work.... its going in a 92 yj, the motor has 68mm throttle body, poweraid spacer, no clue on what injectors, compcam 68-239-4, banks header. i read about every one building these motors and putting back together and starting it up. im about 2 seconds to just about throwing a holly 4bbl on it... help
- Vehicle Year: 1994
Re: ecu question
If you haven't found your answer yet.. Your ECU should be able to compensate for the different cam. No need for the flash.
